The simplest route would be to completely remove the stock stereo system, forget about the CD changer, and connect up the Mk2 to your factory Infinity amplifier as illustrated here. Assuming that your Infinity system is like the one pictured there, you should be able to get the necessary amp adapter parts. Check with PAC to make sure.
You won't miss the CD changer, trust me.
