I agree. Running the cables is the most difficult part of the installation. If you get some ICE magazines and find info on the net, you should be able to do the installation satisfactorily. What type of amp you use is sort of irrelevant once you have th cables there. If you dont skimp on the cable installation you only have to do it once and upgrading the amp later on is easy.
-- Murray I What part of 'no' don't you understand? Is it the 'N', or the 'Zero'?
