Hijack v181 is now available.
The only change from v180 is preliminary support for intercepting/emulating the Tuner/Stalk serial port.
By default, nothing strange should happen with v181.
But if you enable "[hijack] trace_tuner=1" in config.ini,
Hijack will dump out incoming packets from the Tuner/Stalk
serial interface (/dev/ttyS0). Eventually, I'll add button
emulation for these codes, enabling the [ir_translate]
facility to operate on them.
What, no tuner you say? No problem. Here's a way for the
curious to see what the Tuner Display would look like on
your RioCar/Empeg, as if you had a Tuner module installed:
[hijack]
fake_tuner=1
Why bother, you ask? Well.. the Sony Stalk control, which
normally plugs into the Tuner module, has at least one command
not normally available without one: "Visuals-". If we can
fake a tuner, then we can issue that command from [ir_translate]
after first assigning it to another button.. someday soon.
