#67407 - 12/02/200207:32Re: R3Mix Preset in Audiograbber
[Re: TreeRip]
adavidw
Loc: Utah, USA
It's possible that in your first case all the settings were fine, except for some reason the VBR header didn't get written to the file. The symptoms you describe sound a lot like what WinAmp does on a VBR file that doesn't have the appropriate header. I'd use some tool like VBR fix to fix the header, and then see what WinAmp says when you play it.
