In terms of uploading, 1.02 and 1.03 should be more or less equivalent. And they should be stable, even for large uploads. So the problem is either at the PC end or the player end. If the problem is at the player end, I would suspect this problem.
If you can, get a log file from emplode by activating logging just before the upload begins (it's in the options).
