> The problem where Traffic Announce doesn't switch back, isn't, as far as I know, an Empeg bug.
> It's the radio station announcer forgetting to press the proper button at the end of the announcement.
II do have (at least for the moment, with existing headset and no $$ for separate amplifier) the empeg output hooked up to the AUX input of my headset, which happens to have its own RDS-TA function. Both RDS-TA systems switch over to TA if a TA-radio signal is received (the empeg has a delay of 1-5 seconds). The headset returns to AUX mode once TA is finished, the empeg however happily continues to play the radio commercials, even though it switched to TA from player mode.
> At least, not if you're running the latest software, as far as I know. Someone correct me if I'm wrong.
2.b11 with Hijack (Hijack version of a few weeks ago)
Empeg M2A Blue # 010101908 80Gb
Empeg M2A Blue # 030102771 with backlight buttons - Need repair (IDE cable connection on main board) - volunteers?
