Hijack v206 is out.
The new feature-of-the-day is a virtual "Clock" button code, which can be bound to any button (or a popup menu) using the ir_translate features.
When "pressed", "Clock" causes a 4-second popup window to appear with the current time/date in it.
Note that since the Player software does not pass timezone information to the kernel, the time may appear wrong. To combat this, you can specify a time_offset=nnn in config.ini under [hijack. This offset is specified in minutes, and can be preceeded with a minus sign if need be. For example:
[hijack]
time_offset=-300 ; Eastern Standard Time (EST) Canada
Enjoy.
