Ok... you could read the post in technical about bluetooth, but here it is...
Kim has sucessfully installed a self contained bluetooth module (ericsson) which supports data transfer via a bluetooth mobile phone, enabling him to establish a GPRS / Dial up connection to the internet with his empeg via a bluetooth enabled mobile phone...
The Ericsson module also supports voice transfer, via two 8khz PCM data lines (in & out). If the PCM data from the phone could be input to the empeg's board, and output through the DSP, and the corresponding Mic input to the empeg sampled and output off the board to the bluetooth module, the empeg can be turned into a fully featured, generic bluetooth handsfree kit.
The phone would be controlled via bluetooth's 'Serial port profile' just as if it was connected to a PC via a serial cable. This would allow the empeg to display caller id, and let you choose whether to answer, or reject the call.
The processing of the Mic signal would also allow for programming of echo cancellation and road noise reducation via previously established voice coding standards.
Any thoughts?
Oli.
