Sounds more like missed key presses or releases during other activity (playing a beep?)
Interesting idea. I was able to reproduce it with beeps=off, but you could be on the right track. I once worked on a Quake mod that had a similar problem: Sometimes one of the client commands would get "stuck on" if the "off" command came in the same frame as another command. Our work-around was to send the "off" command twice, but we never actually fixed the bug.
-- Tony Fabris -- Empeg #144 --
Caution: Do not look into laser with remaining good eye.
