>And there's nothing in the Kernel sources to give a clue?
Not the info we need, like the internal register addresses for bass/treble control.
On the plus side, while poking at this I "discovered" the cs4231a driver. This is the device that's using FIQs -- the likely source of player lockups. The fix is elsewhere, but at least now I understand where the FIQs are coming from.
This device is used to resample the audio-outputs, providing data for visuals for the Tuner and Aux audio -- and maybe for regular "mp3" visuals as well (don't know, don't care).
It is significant here though, because this is also the device we will use for recording live radio in the Empeg.. and it is a pretty standard device with published APIs etc.. so no barriers there!
I really want to be able to record Tuner output, even while listening to mp3's at the same time, and this device enables it to happen.
