Uhhh...Do you mean 'just stays on' when no button is pressed or only when you press a button.
IR signals are usually modulated onto a 35-50KHz carrier - (38.1KHz is very common), so you would not see any flicker. However, if you are seeing a constant IR beam when no button is pressed then I'm guessing that there is a problem with the remote.
