You are correct about needing a 256fs clock, which is not present on the IIS pads - this was a bit of an oversight, sorry.
However, you should be able to run a flying lead to one end of the 11.2896mhz xtal (next to the DSP) from which the IIS clock is derived - and this will work just fine.
Hugo
