I don't have hijack installed and it was happening since I got the unit about 2 months ago. I tried to set the time 3 times and each time I thought I had set it before which is why I tested it in the manner described. I did that twice with the same affect, the system never seemed to keep time once power had been removed.
After putting 1.3, testing, then putting 2.00 beta 11 back and changing the time again (although it kept the settings from 1.3), I left the power off for 30 minutes and it still had the correct time. This was last night and I need to doublecheck again today, just in case.
Do you have any more info on this "jiffies bug?" If I knew a little more about it, maybe I could recreate the problem somehow.
Thanks,
Daniel
Daniel [blue] 10G MkIIa [/blue] Quantum Mechanics: The Dreams Stuff are made of.
