#100002 - 17/06/2002 22:21 The Empeg doesn't respond to the remote.
AcceptedEclectic
I have a mark2 empeg that works great except with the remote. I believe the problem to be due to the reciever on the empeg. I have looked at the remote through a video camera and saw the infrared flash only when I pushed a button. I also got my remote to work on my friends empeg but his wont work on mine. I have beta 2.11 and the latest hijack installed. Any suggestions?
Justin Larson is smelly.
#100003 - 17/06/2002 22:35 Re: The Empeg doesn't respond to the remote. [Re: AcceptedEclectic]
robricc
I had a faulty IR receiver on my MK2. It worked perfectly for a couple months, then died one day. I sent it to empeg in Cambridge and it worked for them (of course). They replaced the IR receiver anyway, and it's been good ever since.
I'm not suggesting your IR receiver is busted. I'm just letting you know what happened to me. I think the thread I started on the subject was called "Remote Control Oddities."
EDIT: Here's that thread.
Edited by robricc (17/06/2002 22:37)
#100004 - 17/06/2002 22:36 The Empeg doesn't respond to the remote. [Re: AcceptedEclectic]
AcceptedEclectic
Just some more info. This is not a sunlight only problem or a car/home problem. It doesn't seem to work anywhere. Also it started by not working every once in a while now it seems to be always. I also tried it with a learning remote as well to no avail. Any help is appreciated.
#100005 - 17/06/2002 22:37 Re: The Empeg doesn't respond to the remote. [Re: robricc]
AcceptedEclectic
I actually just read your post but how would I contact Cambridge to get mine replaced since I can't see it being ne where else.
#100006 - 17/06/2002 22:41 Re: The Empeg doesn't respond to the remote. [Re: AcceptedEclectic]
robricc
#100007 - 18/06/2002 02:11 Re: The Empeg doesn't respond to the remote. [Re: AcceptedEclectic]
matthew_k
I'm not sure if you have or not from your posts, but you should try out hijack's display of remote codes as you press buttons... It'll give you an idea if anything is getting through at all...
#100008 - 18/06/2002 10:18 Re: The Empeg doesn't respond to the remote. [Re: AcceptedEclectic]
You didn't say whether you had a Rio remote or a Kenwood remote. Did you disable the Kenwood in the player configuration?
And although your text seems to hint that you've read the FAQ on this topic, just in case you haven't read it, click here and make sure you try all of the things listed before contacting support.
#100009 - 18/06/2002 17:19 Re: The Empeg doesn't respond to the remote. [Re: AcceptedEclectic]
AndrewT
Loc: Oxford, UK
Also, have you tried a new (fresh) battery in the remote just in case the discrimination level is different between the two empeg's and all you have is a low(ish) battery?
#100010 - 18/06/2002 18:00 Re: The Empeg doesn't respond to the remote. [Re: AndrewT]
AcceptedEclectic
I tried two new batteries in it since radioshack has been known to hand out the occasional dead battery. And i did disable the kenwood remote since I have the Rio remote. Also I tried using Hijack's button code thing and it showed nothing.
Another note of information. My remote does work every two weeks or so. This will last maybe 10 minutes.
#100011 - 20/06/2002 13:39 Re: The Empeg doesn't respond to the remote. [Re: AcceptedEclectic]
justinlarsen
Loc: Petaluma, CA
We also tried using my remote which works fine on my empeg, and also his remotes works fine on my empeg, im pretty sure its the IR Box.
Ps. also is David still with the team, i remember reading somewhere that hes part time not and evntually going to leave.
---- Justin Larsen
#100012 - 21/06/2002 12:49 Re: The Empeg doesn't respond to the remote. [Re: justinlarsen]
David is still here, still part time, and I guess everyone is EVENTUALLY going to leave!
