could someone point me to the settings/string that will give the highest audio quality VBR?
Now thats a can of worms.....
wander over here 66.96.216.160/cgi-bin/YaBB.pl and also over to
www.hydrogenaudio.org
But if you want to save some time try:
VBR (Variable Bitrate) settings:
Even Higher Quality
Higher Quality (Slower):
--alt-preset extreme
(bitrates 220-270 kbit/s -- usually averages around 256kbps)
Faster (Very Slightly Lower Quality):
--alt-preset fast extreme
(bitrates roughly the same as above)
Very High Quality
--alt-preset standard
(bitrates 180-220 kbit/s -- usually averages around 192 kbps)
--alt-preset fast standard
Compromising, a little bit lower quality than pure standard, but less bitrate (-Y: usually limited up to 16 kHz) :
--alt-preset standard -Y
Personally I am using "--alt-preset fast standard".
Be warned, however, this setting are pretty CPU intensive and therefore it takes quite a while to encode.
