#103818 - 08/07/2002 21:03 Power dies for no reason
willebear
Loc: Louisville, KY USA
I have noticed that sometimes when I turn on my car, the player won't boot. The car was previously just turned off as usual and the player was never told to 'power off'. The LED will be blinking but it does not boot. I then slide the player out of the sled and push it back in and it boots fine.
Today it just quit right in the middle of playing. I didn't notice when b/c the volume was down, but i was listening to music, turned the volume down and then noticed a few minutes later that it was completely off!
What's up?
50 Gig MK2 feat. over 7445 songs, 865 albums by 400 artists for 25 days of easy listening
#103819 - 08/07/2002 21:36 Re: Power dies for no reason [Re: willebear]
Have you enabled any of the screen blanking or timeout features of Hijack?
#103820 - 08/07/2002 22:14 Re: Power dies for no reason [Re: tfabris]
willebear
hijack is not installed.
hijack is wiped out after a fresh install of the main software (2.00 b11), right?
#103821 - 09/07/2002 07:37 Re: Power dies for no reason [Re: willebear]
If the LED is blinking, the the unit is probably still in standy-by from the last time it was "on" -- thus cycling the ignition will have no effect (unless doing so cuts power to the player).
What happens when you just press the top button to bring it out of standby?
#103822 - 09/07/2002 09:33 Re: Power dies for no reason [Re: willebear]
hijack is not installed. hijack is wiped out after a fresh install of the main software (2.00 b11), right?
Correct, Hijack is wiped out after a fresh install of 2.0b11.
However, there is a serious bug in 2.0b11 that is fixed by installing Hijack. This bug might fix the problem you are reporting (although I'm not sure because I'm not clear on the details of your problem). So if you're running 2.0b11, then you should install Hijack, too, in order to fix the bug.
