#104990 - 14/07/2002 09:19 Removing secondary hard disk from empeg?
snoopstah
Loc: Squamish, BC
Hi,
I just (yesterday) installed a 20gb hard disk into my empeg, in addition to the original 10gb disk. It now turns out (for reasons lengthy) that I wish to remove this and substitute it for an 18gb disk.
I've not as yet added any new music to the disk. What are the likely consequences of removing the disk from the system?
Many thanks,
Alexis.
#104991 - 14/07/2002 09:30 Re: Removing secondary hard disk from empeg? [Re: snoopstah]
Greetings!
Well, it depends on if you are removing the master (drive0) or the slave (drive1). Your original 10 was built using the drive builder, and has the boot software on it from the emplode load. The 20 you added was probably also built with drive builder, but may (or may not) have the software loaded. If you replace the boot software on the 10, you need to make certain that at least one of the drives has the player / boot software on it.
Apart from that, it is very easy. All of the music and data files associated are stored in the /driveX/fids directory. The /drive0/var directory holds the database files (database, playlists, tags). These files are automatically rebuilt on every sync, so they can be destroyed without too much concern.
If the drive you are swapping has an empty fids directory, you can swap the drive without any issue. If any music or data was loaded on it, you just need to copy the hex named files from the fids directory elsewhere (the other drive's fids directory) to keep your music in tact. In this case, delete the database files, reboot (it will be slower as it tries to regenerate the files on the fly) and resync.
#104992 - 14/07/2002 10:04 Re: Removing secondary hard disk from empeg? [Re: pgrzelak]
snoopstah
Loc: Squamish, BC
Hi Paul,
Thanks for the comprehensive reply. The 20gb disk was installed as a slave in addition to the primary 10gb disk - it had the player software loaded as well.
I've checked on the FTP, and the folder /drive1/fids has nothing in it. This means I can safely remove this drive without data loss - right? (Just wanting to confirm)
Thanks,
A.
#104993 - 14/07/2002 10:31 Re: Removing secondary hard disk from empeg? [Re: snoopstah]
smu
Loc: Germany (Ruhrgebiet)
Right.
cu,
sven
#104994 - 14/07/2002 11:04 Re: Removing secondary hard disk from empeg? [Re: smu]
snoopstah
Loc: Squamish, BC
Thanks both - hard disk removed without problems.
A.
#104995 - 14/07/2002 12:38 Re: Removing secondary hard disk from empeg? [Re: snoopstah]
Greetings!
Cool. Now it is time to put that 18GB drive in...
