#105260 - 15/07/2002 22:36 Ethernet Disconnects
ajayrockrock
Loc: Riverside, CA
I usually have no problems with ethernet, except when it just randomly disconnects. I read the FAQ and most of those problems are for first-time installations. I can stream music via Hijack and it will shut off and even during emplode sync's it will die. I can connect just fine but after a few modifications to the playlist I can't sync becuase the ethernet connection is gone.
The only way to make sure the empeg stays alive is if I have a dos window open and pinging the empeg's IP address.
Any ideas? Anyone else have this problem?
later,
ajay
#105261 - 15/07/2002 22:51 Re: Ethernet Disconnects [Re: ajayrockrock]
matthew_k
Sounds like it might be a faulty switch/hub? That's a rather strange way to make it work... Have you tried hooking it up with a crossover cable directly to your computer? (And a seccond computer if that doesn't fix the problem...)
#105262 - 17/07/2002 19:13 Re: Ethernet Disconnects [Re: matthew_k]
ajayrockrock
Loc: Riverside, CA
It was a lame Linksys switch. I tried it at work with what my friend called a "proper" 3COM switch and everything was fine. Also I dont' remember having any problems while using a crossover.
later,
ajay
