#106067 - 19/07/2002 14:45 darn it !!
lastdan
Loc: santa cruz,ca
just got around to installing the empeg and ran into a few things:
1. lots of 'drive' noise (engine off)
2. 'back' or 'up' button stuck in? wont work (only pressed it a few times so far, this unit is new)
dimmer w/headlamps flacky at best.
help?
#106068 - 19/07/2002 14:51 Re: darn it !! [Re: lastdan]
I had the sticky button problem, loosening off the four screws on the front, wiggling the offending button and lightly tightening the screws again did the trick. But then again, I change my lenses almost as often as my mood.
As for the headlamp sense, it could be that your headlamp sense wire is PWM instead of a simple voltage level. I know there are a few German cars that use this method.
#106069 - 19/07/2002 14:52 Re: darn it !! [Re: lastdan]
Stuck button and dimmer issues are covered in the troubleshooting section of the FAQ. Engine noise is called a "Ground Loop" and that's covered in the Car Installation section of the FAQ. Check them out.
#106070 - 19/07/2002 14:59 Re: darn it !! [Re: lastdan]
AndrewT
Loc: Oxford, UK
The 'drive noise' is probably a ground loop. I've had some ground loop problems myself.
The sticking buttons are probably covered for you here. The hex screws really don't want to be very tight at all, in fact they have a thread locking compound applied to them which helps them stay put without much force.
Edit: Damn, you guys are quick responding
Edited by Rue (19/07/2002 15:00)
#106071 - 19/07/2002 15:01 Re: darn it !! [Re: tfabris]
tms13
Loc: Lochcarron and Edinburgh
I think lastdan was talking about disk-drive noise - he/she said "(engine off)".
I don't know if there's much that can be done to alleviate that. Check for rattles etc. if the drive is causing vibration somewhere else. It shouldn't be loud enough to hear over engine or road noise though.
So, don't use your player when you're not driving.
Seriously, it does annoy me a little at home, as I go to sleep with the volume really low and the disks are audible then, but in the car it's never a problem. It does probably depend on what drives you have, and on the individual drives.
Toby Speight
030103016 (80GB Mk2a, blue)
030102806 (0GB Mk2a, blue)
#106072 - 19/07/2002 15:04 Re: darn it !! [Re: tms13]
Even so, he's still probably talking about a ground loop. Obviously he doesn't mean the ambient noise created by the spinning of the drive. He means noise coming out of the speakers. Still a ground loop.
#106073 - 19/07/2002 15:20 Re: darn it !! [Re: tfabris]
lastdan
Loc: santa cruz,ca
a: yes you wonderful people are DAMN fast with a reply, thank you.
b. the empeg has 0 miles, or even inches and the engine has yet to run at the same time.
rather solid ground connection. and the drive noise is awful loud.
i'll try the hex screws.
thanks all, have a great weekend.
#106074 - 19/07/2002 16:13 Re: darn it !! [Re: lastdan]
AndrewT
Loc: Oxford, UK
Currently on my empeg, at a lowish volume setting I can hear *everything* that goes on inside (and outside) the player through my speakers i.e. HDDs spinning up, changes on keypresses and so on.
This is all with the ENGINE OFF, with the engine running I additionally get alternator whine.
In my case it's easy to turn the volume up past this background noise and lose it.
Like you, I also have a very good (*star*) ground wiring but am still getting the problem. I have a 'fix' available (ground the player's RCAs) separately which I will implement soon.
The point to this post is to point out that some ground loops can seemingly defy common sense and reasoning based upon sound (no pun intended) electronic experience.
