#107546 - 26/07/2002 10:17 sent in for support... still NO PUMP!!!! AHHHH
jgriffin
well, i sent it in for warranty support and it still wont select a pump device... what the heck is going on. i want my music.
Apparent Newbie
#107547 - 26/07/2002 10:29 Re: sent in for support... still NO PUMP!!!! AHHHH [Re: jgriffin]
Then most likely, either the drive cable came undone in shipping, or there's something wrong with your PC or its serial port. Try performing the upgrade on a different PC to rule this out. Also, it could be a problem with the serial cable, see if you can get a different null modem cable.
#107548 - 26/07/2002 22:15 Re: sent in for support... still NO PUMP!!!! AHHHH [Re: tfabris]
jgriffin
just learned a lesson about being thorough when trying to fix a tech issue. i did !everything! except checking my dc transformer. wow.... went to radioshak and i was in buisness.
just wasnt getting enough juice.
Apparent Newbie
#107549 - 26/07/2002 22:56 Re: sent in for support... still NO PUMP!!!! AHHHH [Re: jgriffin]
Ah, good.
