#107722 - 28/07/2002 10:13 Hijack v286: Several important fixes
Okay, Hijack v286 is now available.
Several fixes make this the best Hijack ever:
-- no more display corruption on reboots
-- The Restore DC/Car Visuals now just issues a down.L keypress on player startup, eliminating all of the complex logic from the past. This requires "notify=1" in config.ini.
-- Hijack is smaller than before, thanks to the above fix.
-- One can now request .xml output for a single tune, as per this thread.
-- The Hijack startup code has been reworked -- hopefully without breaking anything, and possibly fixing some jiffies-wraparound bugs.
Get yours now from the link at the top of this page.
#107723 - 28/07/2002 10:16 Re: Hijack v286: Several important fixes [Re: mlord]
For the curious, I "fixed" the "display corruption on reboots" by having Hijack power-off the display before rebooting. This would indicate a bug somewhere in the regular Empeg kernel startup code, whereby a powered-off display is possibly incorrectly assumed at startup.
#107724 - 28/07/2002 10:20 Re: Hijack v286: Several important fixes [Re: mlord]
Oh yeah, v286 also fixes the "seek tool fix" for the case where the knob has not been remapped at all (blush).
#107725 - 28/07/2002 19:46 Re: Hijack v286: Several important fixes [Re: mlord]
Just a quick note, the new behavior for restore-DC-Car-visuals seems to work well for me now. It is better than the IR_Translate trick because it also works for waking up from standby mode. I like it.
Although the info:SeekTool behavior is odd now. With the last hijack version, I was able to knob-press-through all of the info modes without having to do anything but press the knob. Now, when I get into that screen I have to make a selection at the time I try to leave the screen. Why did it change with this version? The last behavior set worked well.
[Edit: I noticed after I changed the popup to "info" once, it worked that way from then on, so I guess this new behavior is fine now that I understand it.]
#107726 - 28/07/2002 19:48 Re: Hijack v286: Several important fixes [Re: tfabris]
I take that back. The popup action reverts to "SeekTool" instead of "Info" upon reboot, and therefore requires a knob twist on the seektool screen when I try to pushknob through the info modes.
#107727 - 29/07/2002 05:55 Re: Hijack v286: Several important fixes [Re: mlord]
SE_Sport_Driver
Thank you Mark!
#107728 - 29/07/2002 15:31 Re: Hijack v286: Several important fixes [Re: tfabris]
Sheesh! There's just no pleasing them privileged red names, is there?
The earlier version appeared to work nicely only because it was broken in other ways.
I'll put out v287 shortly, with some fine tuning that oughta please your emminence.
#107729 - 29/07/2002 15:42 Re: Hijack v286: Several important fixes [Re: mlord]
I may be the eminence, but you're The Lord.
Thanks, Mark.
#107730 - 29/07/2002 15:49 Re: Hijack v286: Several important fixes [Re: tfabris]
Whatever.
v287 is available now, give it a whirl.
Smoother, but perhaps not exactly as smooth as before (?).
#107731 - 29/07/2002 15:51 Re: Hijack v286: Several important fixes [Re: mlord]
Thanks, trying 287.
Oh, and sorry I didn't mention this earlier today (I only just remembered) but this morning when I started the car, the Bottom.L from the new "Restore DC/Car Visuals" behavior wasn't "L" enough and all it did was open the main menu.
Still work better than the previous behavior, so please don't revert to the old info-cycling thing.
#107732 - 29/07/2002 15:53 Re: Hijack v286: Several important fixes [Re: mlord]
Laura
Loc: Greenhills, Ohio
<waves to Mark>
Laura
MKI #017/90
whatever
#107733 - 29/07/2002 15:57 Re: Hijack v286: Several important fixes [Re: Laura]
<rolls eyes>
#107734 - 29/07/2002 17:08 Re: Hijack v286: Several important fixes [Re: Laura]
<waves back -- totally speechless (laryngitis)>
#107735 - 29/07/2002 18:14 Re: Hijack v286: Several important fixes [Re: tfabris]
ricin
Loc: US: CA
Ditto, I had that happen to me this morning (with v286).
Donato
MkII/080000565
MkIIa/010101253
ricin.us
#107736 - 29/07/2002 18:39 Hijack v288: Restore DC/Car Visuals (again) [Re: tfabris]
Well, it didn't work at all for me, so I've redone it again for v288. Fscking thing works every time now. That player module is a complete mystery to me.
v288. Available shortly
#107737 - 30/07/2002 05:55 Re: Hijack v288: Restore DC/Car Visuals (again) [Re: mlord]
SE_Sport_Driver
It's too bad an insider hasn't gotten you the source yet considering all the help you've provided..
#107738 - 01/08/2002 16:00 Re: Hijack v288: Restore DC/Car Visuals (again) [Re: SE_Sport_Driver]
johnmcd3
word.
1998 BMW ///M3 30 GB Mk2a, Tuner, and 10 GB backup
#107739 - 09/08/2002 06:50 Re: Hijack v288: Restore DC/Car Visuals (again) [Re: mlord]
mavantix
Hijack v291: the DC Restore visuals still doesn't work for me... Hasn't worked for me since v26x something... It's really fusterating, because it's like the only Hijack feature I really want to work!
[green]MK 2 - 40GB - Green[/green]
#107740 - 09/08/2002 07:29 Re: Hijack v288: Restore DC/Car Visuals (again) [Re: mavantix]
check this post
#107741 - 09/08/2002 09:04 Re: Hijack v288: Restore DC/Car Visuals (again) [Re: JBjorgen]
mavantix
Thanks a ton!! That's just the trick!
