#107906 - 28/07/2002 16:08 upgradeing harddrives
SpeedBump
can i clone my two current 15 gig drive and swap them out for two 60 ibm traval stars?
#107907 - 28/07/2002 16:56 Re: upgradeing harddrives [Re: SpeedBump]
Not exactly clone. But after you format them with the builder image and install the player software onto them, you can copy the contents of the FIDS folder for each one onto the new drives and that will work.
Full instructions are in the drive upgrade guide at www.riocar.org .
#107908 - 29/07/2002 10:19 Re: upgradeing harddrives [Re: tfabris]
SpeedBump
so you can't use a cloning tool like ghost, or anything like that?
#107909 - 29/07/2002 10:22 Re: upgradeing harddrives [Re: SpeedBump]
This is a FAQ entry. Please click here.
#107910 - 29/07/2002 10:28 Re: upgradeing harddrives [Re: tfabris]
SpeedBump
Ok that make since, but i have upgraded my Tivo which runs a flavor of UNIX. You can’t run ghost or anything like that if you want to upgrade it. And what I had to do is run a UNIX utility called DD or something like that. Has anybody tried that?
#107911 - 29/07/2002 10:31 Re: upgradeing harddrives [Re: SpeedBump]
Greetings!
Trust me - it is extremely easy to build the drives with the tool provided and then to copy the raw files. I think you will be able to trust the end result more.
#107912 - 29/07/2002 10:34 Re: upgradeing harddrives [Re: pgrzelak]
And like I said, complete instructions are already in the drive upgrade guide. Step by step.
#107913 - 29/07/2002 10:38 Re: upgradeing harddrives [Re: pgrzelak]
SpeedBump
I’m running a two drive system now, and I bought two new drives and I want to make the upgrade easy and fast as possible, with out having to reload all of the music. Because I am not the best at Linux.
#107914 - 29/07/2002 10:42 Re: upgradeing harddrives [Re: SpeedBump]
I don't know how many ways I can say this. The drive upgrade guide has complete step-by-step instructions for how to do this. So just follow the instructions there.
It even mentions your particular case: "For example, if you are replacing both drives instead of just one drive, repeat the entire procedure to copy the files from the old secondary drive to the new secondary drive."
#107915 - 29/07/2002 10:48 Re: upgradeing harddrives [Re: tfabris]
Greetings!
Recommendation: you do not have to split the data between two drives. If I remember correctly, you are going from 2 x 15 to 2 x 60. You could copy the contents from both of your drives onto a single 60 target.
#107916 - 29/07/2002 11:04 Re: upgradeing harddrives [Re: pgrzelak]
Good point. But since he has to swap drives in and out of the player to do the copying anyhow, it really doesn't make it any less troublesome to follow the instructions exactly as written.
Also, there is something to be said for having the files distributed evenly between the two drives.
#107917 - 29/07/2002 11:26 Re: upgradeing harddrives [Re: tfabris]
True. I was thinking that it might be easier than swapping both drives around each time. The important thing is that it is far easier to copy the files than try to duplicate file systems.
#107918 - 29/07/2002 13:16 Re: upgradeing harddrives [Re: SpeedBump]
dd won't work in your case. dd is just a byte-by-byte copy utility, and you're talking about copying the entire filesystem with it. You'd end up copying a filesystem that's the exact same size to your new larger hard drive, wasting the additional space. And you'd have nowhere to put the filesystem from the other hard drive. In reality, there are ways to solve this problem, but they require very advanced knowledge of Linux.
Just follow the instructions that Tony pointed you to. They're as easy as it's going to get.
#107919 - 29/07/2002 14:24 Re: upgradeing harddrives [Re: wfaulk]
SpeedBump
so right now i am formating the disks with the builder.
#107920 - 29/07/2002 15:59 Re: upgradeing harddrives [Re: SpeedBump]
SpeedBump
This is the part that sucks I am copying the two 20gig drives to the two 60 gig drives. And they are both full. So now I wait.
#107921 - 29/07/2002 17:02 Re: upgradeing harddrives [Re: SpeedBump]
Just so you know, it would be even slower with dd.
#107922 - 29/07/2002 17:03 Re: upgradeing harddrives [Re: SpeedBump]
Greetings!
Trust me - it could be worse... Try doing this with any other unit!!! You really would not have gotten any better throughput in any other fashion. If the drives are connected to the same IDE bus, you are at the maximum possible speed.
#107923 - 29/07/2002 17:08 Re: upgradeing harddrives [Re: pgrzelak]
SpeedBump
Well i know when i copy a hard drive useing ghost, with win 2k or some other os on it. i can copy a 20 gig drive quick.
#107924 - 30/07/2002 00:43 Re: upgradeing harddrives [Re: SpeedBump]
Hmm - I reckon you'll find your main limitation will be IDE speed, and that any overhead imposed will be less under Unix than Windows.
Of course I am heavily biased as I can't stand the piece of slow, buggy bloatware that is windows
#107925 - 30/07/2002 07:33 Re: upgradeing harddrives [Re: frog51]
SpeedBump
well i copyed them all and it looks like everything went good. but when it boots i think there may be something wrong.
i get this "Tried to mount /dev/hda4 as reiserfs but got error 19"
but other then that it seems to work great thanks for the help. (if i read the FAQ)
here is the boot log
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.14-rmk5-np17-empeg51 (mac@aphex) (gcc version 2.95.3 20010315
(release)) #16 Wed Jul 24 18:19:54 BST 2002
empeg-car player (hardware revision 7, serial number 90000576)
Command line: mem=12m
Memory: 10968k/12M available (964k code, 20k reserved, 332k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is ffffffff 'ÿÿÿÿ'
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005a00).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IC25T060ATCS05-0, ATA DISK drive
hdb: IC25T060ATCS05-0, ATA DISK drive
hda: IC25T060ATCS05-0, 57231MB w/1768kB Cache, CHS=7296/255/63
hdb: IC25T060ATCS05-0, 57231MB w/1768kB Cache, CHS=7296/255/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:12:02:4
0
Partition check:
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...adonly.
Mounting proc
Starting player
Vcb: 0x40576000
#107926 - 30/07/2002 08:20 Re: upgradeing harddrives [Re: SpeedBump]
Erm, I think it's supposed to say all that. Looks like a good startup log to me.
#107927 - 30/07/2002 08:22 Re: upgradeing harddrives [Re: SpeedBump]
tms13
Loc: Lochcarron and Edinburgh
That's normal, and expected. No problems. I'm surprised this isn't mentioned in the FAQ.
Toby Speight
030103016 (80GB Mk2a, blue)
030102806 (0GB Mk2a, blue)
#107928 - 30/07/2002 09:24 Re: upgradeing harddrives [Re: tms13]
I was hoping it would just disappear in some version of the software.
