#107947 - 28/07/2002 20:38 new mini forum
Does anyone know of a forum for the new mini. I am trying to get more info about them the Golf is turning out to be big POS. (the turbo just blew up and vw is going on week two fixing it)
#107948 - 29/07/2002 00:37 Re: new mini forum [Re: msaeger]
crazymelki
Loc: Switzerland
crazymelki.com
#107949 - 30/07/2002 18:56 Re: new mini forum [Re: msaeger]
mschrag
Loc: Richmond, VA
#107950 - 30/07/2002 19:20 Re: new mini forum [Re: msaeger]
thanks for the links. I actually looked at one yesterday. I parked next to one and it looks about the same size as the golf but the rear storage is about a fourth a much. Man that engine is crammed in there too.
#107951 - 31/07/2002 06:32 Re: new mini forum [Re: msaeger]
boxer
Loc: Yorkshire UK
Depending who you are, this is either a design or nostalgia exercise, not a car based on ergonomics - and I can't see where the Empeg goes - these manufacturers just don't think things through!
#107952 - 31/07/2002 06:57 Re: new mini forum [Re: boxer]
The factory head unit would have to be removed for the empeg.
The seat felt about the same as the golf I would rather have cloth though.
This is the only other decent hatchback I can find other than the golf which has turned out to be crap.
#107953 - 31/07/2002 07:20 Re: new mini forum [Re: msaeger]
Looking for a sporty hatchback with stacks of room (ie will fit two 20" Monitors or all the gubbins needed for 2 babies for a week)??
The Subaru Impreza Turbo. Goes like you wouldn't believe, corners like it's on rails and can fit a family of 4 with luggage easily.
And they're pretty cheap to buy, insure and run.
#107954 - 31/07/2002 07:22 Re: new mini forum [Re: msaeger]
And I thought the Golf GTi Turbo was okay - not staggeringly exciting, but it had some nice features. I especially liked the speed related volume control;-)
#107955 - 31/07/2002 14:19 Re: new mini forum [Re: frog51]
I didn't look too closely at subaru I will have to look again. The AWD kinda scares me because it sounds like more service.
#107956 - 31/07/2002 16:04 Re: new mini forum [Re: msaeger]
thinfourth2
when is the last time you got your gearbox serviced ?
No reason why the 4wd should cause any huge problems as long as you treat it well and look after your oil.
#107957 - 31/07/2002 17:52 Re: new mini forum [Re: thinfourth2]
That's probably true but I'm the one who has turbos die at 45K miles. And brake pads all out and wreck calipers.
#107958 - 01/08/2002 00:58 Re: new mini forum [Re: msaeger]
Actaully, I tend to drive my cars pretty hard and the Subaru holds up bettter, needs less servicing and is cheaper to service than a few other I have had (including Golf GTi T, Audi GT Coupe Sport, Rover 820)
I go through tyres every 12000 miles or so though. 4WD does use them up a wee bit faster than 2WD. Admittedly going sideways at every possible opportunity eats them even faster.
