#108544 - 31/07/2002 06:35
logo edit probs
okay running win2000 and trying to upload a kernal (hijack) i am getting the following message
awaiting prompt then
error: No prompt within timeout
Thankys anybody
Aberdeen Scotland
#108545 - 31/07/2002 07:03
Re: logo edit probs
[Re: thinfourth2]
Greetings!
Double check your cable and connections. Make certain nothing else is connected on your serial port as well. It sounds like you are not getting connectivity.
#108546 - 31/07/2002 09:54
Re: logo edit probs
[Re: thinfourth2]
What software is being used to send the kernel? If it is my logo editor, go through everything here to make sure that you can communicate with the player at all on the serial port. Make sure you can send and recieve text with Hyperterminal. If that works, then the logo editor should work.
If you are not using my logo editor, then use my logo editor.
#108547 - 31/07/2002 09:56
Re: logo edit probs
/me re-reads the title of the thread and realizes that you were using logo edit. Sorry.
#108548 - 31/07/2002 10:08
Re: logo edit probs
Loc: Lochcarron and Edinburgh
If you're having serial problems, you could use Hijack's FTP server to store it to /proc/empeg_bootlogos. But you probably want to get your serial working anyway (for next time you have to put Hijack onto a new official player release).
[Hmm, wonders... - it must be possible to remove the kernel chunk from an Empeg *.upgrade file, leaving Hijack in place providing /proc/empeg_kernel, and never needing serial again. Didn't smu write a packager? What would be really cunning would be to write an unpackager to run in the player kernel so we could send an upgrade file to /dev/empeg_upgrade and have it write the disk partitions etc. Not sure that it would work while the kernel is running, though.]
#108549 - 31/07/2002 10:11
Re: logo edit probs
[Re: tms13]
If you're having serial problems, you could use Hijack's FTP server...
I believe that he's attempting to install hijack via the serial cable after upgrading to beta13. So he can't use FTP until after Hijack is installed. Chicken and egg, get it?
#108550 - 31/07/2002 10:22
Re: logo edit probs
Oops, I shouldn't believe that I can remember everything with a quick glance at the subject line.  My advice is only good for uploading logos (or, by using /proc/empeg_kernel, kernels) with Hijack already operational.
But the good side is that you (thinfourth) know that your serial connection works, as you managed to apply the Empeg upgrade file. Chances are, you're suffering one of the usual annoyances, like having some other process holding onto the port.
#108551 - 31/07/2002 11:16
Re: logo edit probs
okay i can send logos and i can also connect via hyperterminal
any clues tony ?
Aberdeen Scotland
#108552 - 31/07/2002 11:31
Re: logo edit probs
[Re: thinfourth2]
Try removing the power from the player and applying power only when prompted by the software.
If that doesn't work, try running it on a different PC.
#108553 - 31/07/2002 11:47
Re: logo edit probs
Ah ha i have got it
Logoedit don't like it when you are getting a file from another computer over a network, we my network at least.
Being lazy sod downloaded hijack to computer connected to net directly and then used laptop to upgrade, copied file to laptop and then there was no probs. Another day and another bit of knowledge.
i really needed to put hijack on for a really important reason buggered if i can remember what it was though
Edited by thinfourth2 (31/07/2002 11:59)
Aberdeen Scotland
#108555 - 31/07/2002 14:04
Re: logo edit probs
and how do i map a drive letter?
Aberdeen Scotland
#108556 - 31/07/2002 14:39
Re: logo edit probs
[Re: thinfourth2]
right click my computer. click map network drive. enter unc path
Oliver
#108557 - 31/07/2002 14:40
Re: logo edit probs
[Re: thinfourth2]
Right click on Network Neighborhood and select "Map Network Drive".
#108558 - 31/07/2002 14:44
Re: logo edit probs
It amazes me that Windows is such a piece of crap that you're having this much trouble just simply parsing a file name.
Edit: And it's not like this is the only thread today on Windows filename parsing. There's at least one other.
Edited by wfaulk (31/07/2002 14:45)
#108559 - 31/07/2002 14:51
Re: logo edit probs
I'm not having trouble parsing a file name.
It's the command-line interpreter that feeds the file name to the UPLOAD.EXE code. Command-line code under Windows is all old throwbacks to DOS, which didn't have network UNCs. You can't send a network UNC path to an old command-line app, at least not without a lot of special-case code.
Ideally, I would completely remove the UPLOAD.EXE command line applet and have the logo editor grab the COM port directly and do all of the handshaking work itself. If I did that, then there wouldn't be an issue.
However, that's a lot of work. It was easier just to use the existing DOWNLOAD.C code from Hugo and recompile it for Win32 with an extra parameter. That's what made the difference between Logo Editor becoming a reality and being just a dream. If I'd had to rewrite all the serial communications protocol stuff, I wouldn't have ever finished it. Maybe not even started it.
So, as a result, my code has to mash the path down to a short-file-name that's acceptible to pass on the command line to DOWNLOAD.C. And if it's a UNC, it can't mash it into a short-file-name (by definition).
Hence the error when trying to work with UNCs as fed to UPLOAD.EXE.
#108560 - 31/07/2002 15:59
Re: logo edit probs
Like I said. Piece of crap.
(BTW, I wasn't implying that it was your fault or the fault of your program.)
#108561 - 26/10/2002 17:50
Re: logo edit probs
Loc: Newfoundland, Canada
Sorry to bring an old topic up but I have had the same trouble tonight. I think I have figured it out.
Logoedit will not find the Command Prompt if the upgrade file is on a read only network share. I could not get it to work in any way, shape or form. But then I ran upload.exe manually (from the command prompt) and it worked. I figured that 'Command Prompt' was the promt that couldn't be found. I then copied the hijack file the the local computer and uploaded it no problem with Logoedit -- success. Then I tried changing permissions on the share to allow read and write access to the share with the hijack file and then applied across the network and voila! It worked!
So there you go... it seems that it has no problem with network shares... as long as they are read and write shared.
Just thought I'd share this with you all, and you as well Tony... maybe a small change you can make so this problem doesn't rear it's ugly head again.
René
12 gig empeg Mark II, SN: 080000101 30 gig RioCar SN: 30103114 My blog
#108562 - 26/10/2002 21:58
Re: logo edit probs
[Re: ShadowMan]
It tries to convert the path to the file into a "short file name", i.e., drive letter, colon, backslash, and 8.3 file names. It does this because the command line to the "download.c" code is space-delimited and won't take long file names. If it's on a network share that doesn't have an assigned drive letter (it's being accessed with the UNC beginning with a double back slash), the short filename conversion won't work. Are you sure it was because the network share was read-only, or was it because you mapped a drive letter to that network share at some point and it worked after that?
#108563 - 04/11/2002 12:20
Re: logo edit probs
No drive mapping involved whatsoever. I simply shared my downloads folder with write permissions and logoedit now works fine. I don't have a single mapped drive on my home network.
