#110555 - 12/08/2002 06:37 Fan Header on Main Board
benjammin
Loc: Champaign, IL
I'm also in the mood to install a fan. My empeg gets really hot in my Jeep and I don't have A/C (hey - it's a jeep!).
So, watching the temp with hiJack - I decided a fan would be nice.
The question: The header on the mainboard doesn't seem to put out any voltage. What gives?? Did all you guys just tap onto the 12VDC someplace else??
Let me know and thanks,
-Ben
#110556 - 12/08/2002 06:48 Re: Fan Header on Main Board [Re: benjammin]
Both pins are 12V I believe. You'll need to use the case as ground.
- Trevor
#110557 - 12/08/2002 07:03 Re: Fan Header on Main Board [Re: tman]
benjammin
Loc: Champaign, IL
How Bizarre...
I'll check that out... can anyone else verify?
Thanks,
-Ben
#110558 - 12/08/2002 07:16 Re: Fan Header on Main Board [Re: benjammin]
Yep. Look here for a previous thread on it.
- Trevor
#110559 - 13/08/2002 10:51 Re: Fan Header on Main Board [Re: benjammin]
csf
Loc: Charlotte, NC
I've got the same problem... well almost. I do have A/C, but it's not as useful as most A/C units when the top and doors are in the garage. I always have over-heating issues w/ my 2 drive unit when the temp is over about 90 degrees outside.
10+40 Gig Mk2a... with Tuner. S/N 040103784 || 2001 Jeep TJ, 60th Anniversary Edition
#110560 - 14/08/2002 07:06 Re: Fan Header on Main Board [Re: benjammin]
mrfixit
Be shure to read this
Ben
hijacked
#110561 - 15/08/2002 23:07 Re: Fan Header on Main Board [Re: mrfixit]
benjammin
Loc: Champaign, IL
I did... I didn't like the design.. not that's it's bad - but I would prefer a design that turns the fan off/on. It's not good to undervoltage some of those fans out there.. they can do kooky things... so I'm going to do something a little different..
Hey - does anyone know if there's an SPI interface inside the Empeg? I did read the onboard temp sensor is a DS1821 (or 1820) which are 1-wire devices.. mine works.. and I was thinking of using either a DS1721 or a 1-wire thermostat, if they have on... any prefs for anyone?? I suppose if one exists and is useful, I'll make the design for that in case anyone wants to write a hack to control the fan. I figure they could wire it to the adjustable temp-warning alarm which would reset the thermostat as well. When the alarm goes off at the new setting, so does the fan..
Comments, anyone?
-Ben
#110562 - 15/08/2002 23:24 Re: Fan Header on Main Board [Re: benjammin]
benjammin
Loc: Champaign, IL
Ok, looking back... there is no 1wire thermostat - really.. in order to go standalone, I'd have to use one of the other offerings, like the 1721 or the 1621 or the 1620... would any of the kernel hackers out there have a pref??
SMBus (I2C), or SPI (3wire)???
-Ben
