#110657 - 12/08/2002 16:59 Visual auto change on timeout
Aragon
Loc: Cape Town, South Africa
Hi,
I set my favourite visuals to auto change on a 2 minute timeout. However, when the player software restarts (choosing the 'quit' option from the menu) or the empeg reboots, the timeout value reverts to about 30 seconds (haven't timed it). What's odd is that when I go back to the menu to reset it back to 2 minutes, the popup screen where you set the timeout already has 2 minutes as the value. This leads me to believe that the setting is being saved, but only being applied correctly when explicitly set.
I'm able to disable auto change and it reverts back to being disabled on a reboot. Am also able to set it to auto change on track changes, which also gets saved on a reboot. I'm running 2.0b13 with Hijack v289. I found some past threads that are similar, but not quite the same. Was wondering if anyone else experiences this?
Thanks,
Aragon
#110658 - 12/08/2002 21:25 Re: Visual auto change on timeout [Re: Aragon]
Added to internal bug list.
#110659 - 13/08/2002 03:23 Re: Visual auto change on timeout [Re: tfabris]
Aragon
Thank you.
#110660 - 20/08/2002 08:05 Re: Visual auto change on timeout [Re: Aragon]
Indeed. FITNR.
