#110848 - 13/08/2002 17:43 rebooting empeg :(
fbleagh
I grabbed filters new album yesterday and was listening to it on the way home, when my empeg spontaneously rebooted.
It did this quite a few times, mostly have a large bass passages.
my setup isn't extravagnat by any means.
Empeg --> 50W x 4 channel amp --> 2 4" drivers inthe front and 2 6.5" in the rear.
Any ideas on what is causing this and how i fix it ?
#110849 - 13/08/2002 19:14 Re: rebooting empeg :( [Re: fbleagh]
Plug the empeg in at home and play those tracks. Maybe the mp3s are bad somehow and causing the player to screw up.
#110850 - 13/08/2002 19:23 Re: rebooting empeg :( [Re: wfaulk]
fbleagh
If i turn the volume down it doesn't reboot.
the only thing i can think of is that the sense lead on the amp is not isolated and my amp is trying to draw more current down the sense lead ?
i can play the album all the way through at low volume with np's
#110851 - 13/08/2002 19:28 Re: rebooting empeg :( [Re: fbleagh]
Maybe you have the signal and power leads to your amp swapped so that the amp is trying to draw its power through the empeg instead of straight from your power source (battery? I forget).
#110852 - 13/08/2002 19:53 Re: rebooting empeg :( [Re: wfaulk]
fbleagh
nothing so simple i suspect
i would ahve blown the fuse in my empeg if i had done that.
any other things u can think of ?
#110853 - 13/08/2002 19:57 Re: rebooting empeg :( [Re: fbleagh]
matthew_k
Maybe that your alternator can't handle your amp? I realize that's not a big amp, but maybe your alternator or battery is going bad... Does the player display the low voltage icon before it reboots or anything? Can you try puting a capacitor before your amp to see if it's drawing too much current on the low bass notes?
#110854 - 13/08/2002 19:58 Re: rebooting empeg :( [Re: fbleagh]
It's been reported before....
#110855 - 13/08/2002 20:28 Re: rebooting empeg :( [Re: matthew_k]
fbleagh
Yeah it did display the battery signal.
I will try and pick up a capacitor to try, any suggestions on the size i would need ? .5 farad ?
#110856 - 14/08/2002 05:13 Re: rebooting empeg :( [Re: fbleagh]
F0X
Loc: Alberta, Canada
I think the general rule of thumb is 1 farad / 1000 Watts. So if you just have the 4 channel amp, then 0.5 farad should be good.
F0X 3xMkIIa
#110857 - 14/08/2002 09:05 Re: rebooting empeg :( [Re: fbleagh]
Fbleagh, please read this, it covers your problem exactly and it is very specific.
