#110922 - 14/08/2002 11:50 Player sometimes crashes after sync
tms13
Loc: Lochcarron and Edinburgh
I have player 2.0b13 on Hijack v291(IIRC - I'm currently uploading a few CDs).
When I sync, sometimes the player falls over and restarts itself after it's built the database (when emptool is about to restart it anyway, but emptool gets out of sync here and doesn't see that it's restarted). I get the following on the console; I hope it's useful to someone:
ext2fs_check_if_mount: No such file or directory while determining whether /dev/hda4 is mounted.
e2fsck 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09
ext2fs_check_if_mount: No such file or directory while determining whether /dev/hdc4 is mounted.
player(9): memory violation at pc=0x020da668, lr=0x00000000 (bad address=0x35485d2c, code 2)
pc : [<020da668>] lr : [<00000000>]
sp : bffffc6c ip : bffffc8c fp : bffffc88
r10: 02149f34 r9 : 0214fc5c r8 : 0214fc6c
r7 : 021529f8 r6 : 021493a8 r5 : 021521f0 r4 : 00000808
r3 : 35485d28 r2 : 00000809 r1 : 33333330 r0 : 021493a8
Flags: nzcv IRQs on FIQs on Mode USER_32 Segment user
Control: C0F5917D Table: C0F5917D DAC: 00000015
Function entered at [<020da564>] from [<020da534>]
r7 = 0214FC44 r6 = 0214FB90 r5 = 021521F0 r4 = 021493A8
Function entered at [<020da48c>] from [<020c17e4>]
r5 = 00000003 r4 = 021521A0
Function entered at [<020c1760>] from [<0207efdc>]
r10 = 0214FC38 r9 = 0214FC5C r8 = 0214FC6C r7 = 0214FC44
r6 = 0214FB90 r5 = 00000003 r4 = 021521A0
Function entered at [<0207efb4>] from [<02061fd8>]
r5 = 0214FC50 r4 = 00000054
Function entered at [<02061e4c>] from [<020ab6ec>]
r10 = BFFFFEE4 r9 = 00000001 r8 = 0214A1A8 r7 = BFFFFEE8
r6 = 00000086 r5 = 00000002 r4 = BFFFFE84
Function entered at [<020ab6ac>] from [<0207478c>]
r4 = BFFFFE84
Function entered at [<0207476c>] from [<0202f17c>]
r5 = 00000002 r4 = BFFFFDF4
Function entered at [<0202f10c>] from [<02031114>]
r5 = 00000001 r4 = BFFFFDF4
Function entered at [<02030eec>] from [<0203121c>]
r10 = 020311B8 r9 = 00000000 r8 = 0210F0E8 r7 = 00000000
r6 = 020000C0 r5 = 00000001 r4 = BFFFFF64
Function entered at [<020311b8>] from [<020c5f30>]
r5 = BFFFFF64 r4 = 00000001
Function entered at [<020c5e54>] from [<02000104>]
r10 = 00000000 r8 = 00000000 r7 = 00000000 r6 = 00000000
r5 = 00000000 r4 = 00000000
Restored terminal settings
Abnormal player termination
Player received signal 11
Starting player
(Note that the first few lines are the normal output of fsck, and the stack trace doesn't appear until the end of the upload, several minutes later)
Toby Speight
030103016 (80GB Mk2a, blue)
030102806 (0GB Mk2a, blue)
#110923 - 14/08/2002 12:17 Re: Player sometimes crashes after sync [Re: tms13]
tms13
For comparison, here's the corresponding part of a normal, succesful sync:
Restart code received
Starting player
Toby Speight
#110924 - 14/08/2002 12:22 Re: Player sometimes crashes after sync [Re: tms13]
tarkie
Does it do this without HiJack installed?
M2a/Smoke/60gb/Tuner!! Thanks Joe M2a/Blue10gb Thanks Ian!
#110925 - 14/08/2002 13:21 Re: Player sometimes crashes after sync [Re: tarkie]
tms13
I don't know - since it only happens occasionally, and the sync is generally successful, it's only a minor irritant, and I haven't been sufficiently motivated to uninstall Hijack and try it. But I could do so if the Empeg team ask.
Toby Speight
#110926 - 03/09/2002 11:16 Re: Player sometimes crashes after sync [Re: tms13]
tms13
I get the exact same stacktrace with jEmplode, too (v42pre5).
Toby Speight
