#112314 - 21/08/2002 12:21 Checking Media
Does anyone know exactly what goes on in the ``Checking Media'' phase of connecting with emplode?
I'm trying to get this RAID stuff to work, and I've got a mounted RAID set, but, for whatever reason, it fails the ``Checking Media'' step, and will never connect. It's the same over USB, Serial, and Ethernet.
Does the player usually recieve a restart code (``Restart code received'' from the serial console) at this point, after fscks have been performed?
Is it possible that it's actually failing the next step and emplode is misreporting it?
I know this has all been brought up before, but I obviously don't have the recourse to just reinit the player to solve it.
#112315 - 21/08/2002 15:02 Re: Checking Media [Re: wfaulk]
Can someone in the know confirm or deny that it might be failing because it wants the hdc4 fsck to work because it sees that /proc/ide/hdb exists?
#112316 - 21/08/2002 20:11 Re: Checking Media [Re: wfaulk]
Well, it turns out that it wasn't the fsck that was the problem. It was that it was failing to mount the filesystem even though it thought it had an hdc available. I fixed this temporarily by pointing /dev/hdc4 to /dev/hdc5 and it started working.
