#112517 - 22/08/2002 12:09 EAC-LAME Question
DBALKUNJR
I have a few CD's that are not found in the CDDB database by EAC when I insert it in the CDROM drive. How can I add the information? And is EAC or LAME creating the ID3 tags? I hav elooked in all the options in EAC and I can not find a switch to turn this option on or off. I can not find anything like this in my version of RazorLAME either. Any insight would be appreciated.
Dave
MK2 12Gb
MK2a 60Gb
#112518 - 22/08/2002 13:04 Re: EAC-LAME Question [Re: DBALKUNJR]
In order to change the track titles, just click on the track to highlight it, then click again to make it editable. Don't do it too fast or you'll double-click. The artist and album info is at the top, to the right of the toolbar.
I think EAC is making the ID3 tags, but the option is under EAC->Compression Options...->External Compression->Add ID3 Tag.
#112519 - 22/08/2002 13:48 Re: EAC-LAME Question [Re: wfaulk]
Ezekiel
Loc: NH USA
I find that using the F2 key is a bit simpler than trying to time the picky double-click in EAC. (Highlight, F2, type)
-Zeke
WWFSMD?
#112520 - 22/08/2002 15:35 Re: EAC-LAME Question [Re: DBALKUNJR]
ajayrockrock
Loc: Riverside, CA
make sure you fill out all the info and submit it back to the FreeDB. Just select Database->Edit CD Information and put a genre in there. Then select Database->Submit CD Information to freedb. I just finished my entire collection and submitted at least a couple hundred CD's. Also if the titles are incorrect, then fix them and submit them back.
later,
ajay
