Okay, this week I got a new car, and installed the empeg in it. Installation is pretty easy with just the memory power, accessory/ignition power and ground, I had not installed the amp yet. When I put the key in, and turned the car on, the empeg powered up fine, and started to play as normal. I ran the blue wire (remote turn on) to the back where my amp was, installed the amp correctly, triple checking every connection. I then went to power on the empeg after everything was installed correctly, the empeg turned on, the amp turned on, and then after 10 seconds, everthing turned off. I checked all fuses, and everything was good. I then just made a little jumper wire on the amp and put the 12v+ power to the remote turn on, and the amp turned on fine, so I know it wasn't the amp.
I later put a +12 volts to the remote turn on, and then the empeg turned on. What the heck? Now the only way to turn on my empeg is to put an input voltage to my remote turn on from the back of the empeg. This is what I need to get fixed. I'm sure all the other connections are perfect.
Right now I have my accessory switch going to my empeg accessory, amp, and remote turn on from the empeg, and everything works, but this isn't how it's supposed to work. It's supposed to be acessory to the empeg accessory, then remote turn on from the empeg to my amp.
Can someone please help?
