#113577 - 28/08/2002 19:31 I hate C and function pointers.
mschrag
Loc: Richmond, VA
Give me interfaces any day.
#113578 - 28/08/2002 21:02 Re: I hate C and function pointers. [Re: mschrag]
Ehh. Yer jes' lazy.
#113579 - 28/08/2002 21:39 Re: I hate C and function pointers. [Re: wfaulk]
mschrag
Loc: Richmond, VA
I look at this:
sp_rv
sp_generate_signature (sp_audio_info_t * song_audio_format,
sp_signature_t * signature,
guint (*get_pcm_data) (guint sample_offset,
guint num_samples,
guchar * output_buf,
void *user_data),
void *user_data)
and it makes my heart hurt. I'm so glad I only visit C world long enough to port it to Java world.
Then again, in the source to javazoom, a pure java MP3 decoder, there exists the line:
fs = (fs>32767.0f ? 32767.0f : (fs < -32767.0f ? -32767.0f : fs));
the ?: operator is the devil.
#113580 - 28/08/2002 23:02 Re: I hate C and function pointers. [Re: mschrag]
Don't say things like that . I love the ?: operator. Just make sure it's commented properly and there's no problem. I even have ?: nested 4 and 5 deep.
#113581 - 28/08/2002 23:06 Re: I hate C and function pointers. [Re: mschrag]
I disagree about ?:. What is the devil is random magic numbers. He just couldn't make 32767 a constant, could he?
Of course, some indentation could be useful in that function declaration.
#113582 - 29/08/2002 02:29 Re: I hate C and function pointers. [Re: mschrag]
sp_rv
guint num_samples,
void *user_data),
void *user_data)
C's insane type declarator syntax can usually be sanitised by introducing typedefs everywhere it gets hairy:
typedef guint (*get_pcm_data_fn) (guint sample_offset,
guint num_samples,
void *user_data);
sp_rv
get_pcm_data_fn fn,
void *user_data)
but even so the typedef itself remains a bit icky.
#113583 - 29/08/2002 05:25 Re: I hate C and function pointers. [Re: wfaulk]
mschrag
Loc: Richmond, VA
I definitely agree about magic numbers ...
#113584 - 29/08/2002 05:32 Re: I hate C and function pointers. [Re: Shonky]
mschrag
Loc: Richmond, VA
I just always prefer clarity over brevity ... I suppose if properly commented, ?: can be OK (certainly a SINGLE ?: does not return true from my devil function -- which, curiously enough, is: boolean isDevil = (hasQuestionColon) ? ((hasMoreThanOne) ? : true : false) : false, I guess I just find if/else's much easier to follow, and much easier to go back and modify later, whereas the syntax of nested ?:'s is so fragile that you have to really work at changing it.... But that's just me
#113585 - 29/08/2002 05:37 Re: I hate C and function pointers. [Re: peter]
mschrag
Loc: Richmond, VA
Yeah -- It's definitely not fair to condemn a feature based on one of the more confusing examples of its use
#113586 - 29/08/2002 05:58 Re: I hate C and function pointers. [Re: mschrag]
tms13
Loc: Lochcarron and Edinburgh
boolean isDevil = (hasQuestionColon) ? ((hasMoreThanOne) ? true : false) : false
Using conditional operator with only true or false as results is just gratuitous obfuscation
More than one on the same line is bad, but I have no problem with multiple ?: operators if they are laid out as if-elseif-elseif-else (which is great because you don't need loads of parens), or as a binary chop or some other recognisable structure, with a line for each test and each result, and indented sensibly.
Toby Speight
030103016 (80GB Mk2a, blue)
030102806 (0GB Mk2a, blue)
#113587 - 29/08/2002 06:08 Re: I hate C and function pointers. [Re: tms13]
mschrag
Loc: Richmond, VA
I couldn't think of anything funny to put there that wasn't just true/false I should have made it a recursive infinite loop, so instead of true, i had isThisADevil()... Hindsight.
#113588 - 29/08/2002 06:28 Re: I hate C and function pointers. [Re: mschrag]
tms13
Sorry if I wasn't clear - I know you put true and false there as a joke, but I have seen (too much) real code that does that sort of thing.
Toby Speight
#113589 - 29/08/2002 07:50 Re: I hate C and function pointers. [Re: mschrag]
Nah. You just have to wonder about some programmers when they do things like this:
(xyz ? func_1 : func_2)(arg1, xyz ? arg2 : arg3);
I've got a library for a expansion board that is full of things like that for some reason. They're actually a little more complicated but you get the general idea. Must have had an aversion to using if/else
- Trevor
#113590 - 29/08/2002 08:20 Re: I hate C and function pointers. [Re: mschrag]
grgcombs
Loc: Dallas, TX
You and me both buddy. There's got to be a better way.
Then again, I've been known to use a goto here and there.
Greg
#113591 - 29/08/2002 11:29 Re: I hate C and function pointers. [Re: tman]
Hah! Took me a while to parse that. Pretty damn funny. I'm going to have to start using that all over the place, just to annoy folks.
