#115343 - 08/09/2002 18:27
WHEW! I just had the biggest scare of my life!
Loc: Maryland
Pulling the extension cable connected to the power strip connected to the cable connected to my empeg.....PULLED MY EMPEG TO THE HARD CONCRETE!!!!!
I picked my baby up and applied several long kisses and got that horrifying message....HARD DRIVE NOT FOUND.....
I almost died. Luckly, I was able to open the case and push the IDE drive cable back in place, and thankfully, my poor abused empeg booted up.
I promised never, ever to misstreat my poor baby ever again. Now I need to find some kind of industructable case with inputs for power and RCA outs, so my empeg will be ready for my next attempt at DJ'ing the community block party.
Word to the wise.....treat your empeg right, and it'll treat you right.
Mike
Edited by smitty225 (08/09/2002 18:48)
10gig MK2a - Blue Screen
s# 040103813
#115345 - 08/09/2002 18:49
Re: WHEW! I just had the biggest scare of my life!
[Re: DarkStorm]
Loc: Maryland
Yikes! Thats my kind of attention to detail....
s# 040103813
#115346 - 08/09/2002 18:49
[Re: DarkStorm]
Loc: Maryland
s# 040103813
#115347 - 08/09/2002 20:14
[Re: smitty225]
You can say that again!
#115348 - 08/09/2002 21:25
[Re: smitty225]
Anonymous
Unregistered
i usually keep a 15 lb. weight on my power cord so just in case it gets pulled like that it'll have to pull that 15 lb. weight off first.
#115349 - 08/09/2002 22:41
[Re: smitty225]
Loc: Houston, TX, USA
Biggest scare of your life?
Dude no offense, but it's only a car stereo...
#115350 - 08/09/2002 23:20
[Re: jnmunsey]
only a car stereo?
Repent, you sinner!
#115351 - 09/09/2002 04:12
[Re: ]
Loc: Oxford, UK
That conjurs up images of those Roadrunner cartoons:
It all goes horribly but predictably wrong - the empeg hits the ground first and makes a soft landing only to be followed by the 15lb weight then crashing down on top of it!
#115352 - 09/09/2002 06:17
[Re: AndrewT]
Loc: Maryland
Hmm, better upgrade that weight to 45 lbs at least.
Or maybe simply install the empeg in an airline black box. Then it should be able to survive all sorts of disasters.
BleachLPB
NewFace MK2a
#115353 - 09/09/2002 08:21
[Re: BleachLPB]
Loc: Houston, TX
This always raises the question, why don't they just make the entire plane a black box so it survives a disaster?
--Ben 78GB MkIIa, Dead tuner.
#115354 - 09/09/2002 10:31
Re: black boxes :-D
[Re: BAKup]
Loc: San Jose, CA
I'm sure they could, but it comes down to human psychology. There are about a million and a half things that could be done to significantly reduce injury and are within reach of cost and technology for us to do but many people will not accept it.
For example, did you know if you reversed the orientation of the airline seats so that they faced backwards would significantly prevent death and injury in a big way, especially if the plane plows into the ground headfirst? People won't allow it, it's too disconcerting to fly "backwards." It would prevent people from getting split into two by their seatbelts, and prevent people from flying into a bulkhead at hundreds of miles an hour if their seatbelt fails or if a child is being held in their laps. And why even allow children to be "held in the lap" ? Even babies should pay full fare and get full protection in the event of a crash right? People won't allow it. Why have windows, these are essentially holes in the side of an otherwise strong structure, plugged with plastic. People won't allow it. The luggage compartments should lock automatically when the e-brake on the plane is disengaged, because when air turbulence or a crash occurs, heavy metal luggage comes flying out, decapitating people. People won't allow the luggage to be locked away. The latest small aircraft are equipt with a parachute....for the *entire plane* -- so that when something goes wrong, the parachute comes out and lands the plane vertically. It completely and utterly trashes the plane, but saves everyone on board. Airliners have demonstrably been shown to be landable entirely by autopilots using GPS. Military planes like those used in afghanistan can be controlled entirely by remote control. If cruise missiles can fly at mach 10, 20 feet from the ground, avoiding trees and buildings, travel hundreds to thousands of miles and hit a target the size of a pea, then certainly it is within the capability of autopilots to safely maneuver commercial passenger jets. Sheesh, even for autopilots to take over in the event of an emergency. But people won't allow it.
Calvin
#115355 - 09/09/2002 11:08
Re: black boxes :-D
[Re: eternalsun]
it always feels good to vent, doesnt it?
customsex
#115356 - 09/09/2002 11:23
[Re: BAKup]
Um, because the black box doesn't even always survive. People have this image that the black box is made out of some magical indestructible material that will survive a serious catestrophic event like a plane crash. I seem to recal that a lot of the time the black box is dead as well, or at least not in great shape.
#115357 - 09/09/2002 11:26
I thought the reason was: If they armored the plane the way they armored the black box, it would be too heavy to fly.
#115358 - 09/09/2002 11:26
[Re: BAKup]
Loc: Louisiana, USA
Too expensive. Airlines are there to make money. Many aren't making much now. If all the strongest and latest in advanced materials, electronics, and construction techniques were used, planes would be far too expensive to fly both from a fuel economy standpoint as well as cost of ownership. So safety in planes is a trade-off. The same could be said for cars. They could all be built like tanks, but not many of us would be able to afford them. There is an economics article that I believe was called something like "Airline Safety- How safe is too safe?" that covers all this in great detail.
Stu
#115359 - 09/09/2002 11:34
Yeah. There was a programme on Discovery a while back about blackboxes. Depending on when it was installed, the amount of data it records can vary wildly from only a few sensors to hundreds of different values.
The actual thingie that does the recording is tiny but the padding and shielding it needs to survive a plane crash and possibly sit in a pool of burning aviation fuel makes it so big.
- Trevor
#115360 - 09/09/2002 12:06
[Re: tman]
Loc: Mississippi State University
Not to mention on a comercial aircraft there is not just one black box but somewhere around 50, all flight data recorders. its just the cockpit box that records all transmissions that is so famous.
Lucas S.
Starkvegas, MS
#115361 - 09/09/2002 12:10
[Re: dodgecowboy]
Yup. And it's not actually black
- Trevor
#115362 - 09/09/2002 12:14
[Re: maczrool]
Loc: Houston, TX
Remind me next time I'm trying to be funny, to put a ![](/images/icons/smile.gif) or even a ![](/images/icons/crazy.gif) at the end of it.
I know all the reasons, and all the things they can do to make things safer, I was just trying to be funny. But at least I started a discussion on the topic.
#115363 - 09/09/2002 12:30
[Re: BAKup]
Heh, well you certainly picked an old, over-used cliched joke to be funny with.
(The "why don't they make the airplane out of the black box" line is often used when someone is trying to do a parody of a bad comedian... Sort of like a more subtle version of "take my wife please". I've seen it in a couple of movies and also used as part of a practical joke at a standups convention.)
#115364 - 09/09/2002 12:36
[Re: BAKup]
Loc: Hants, UK
They should build them from stuff they used to make the children's doll that is inevitably found amongst the wreckage?
Gareth
#115366 - 09/09/2002 14:03
Okay, now THAT is funny.
Though hardly original. I just saw that exact line on Red Dwarf last night.
It was on the episode where they accidentally crash Starbug while navigating
a meteor field occupied by Psirens.
Lister explains to Cat that Starbug is safe in these crashes because it is
made of those very dollies.
#115367 - 09/09/2002 14:09
[Re: smitty225]
You're lucky you didn't kill the display by breaking the filler neck.... OOOhh, big money!
#115368 - 09/09/2002 14:47
[Re: music]
Loc: Hants, UK
Damn! Found out!
Seriously though, I couldn't remember where I heard it otherwise I would have given it due credit. Red Dwarf is well embedded in my psyche though I haven't seen much since Series VIII on BBC2... I do know a few people who could read off entire scripts word-perfect.
Series 1 is coming out on DVD very soon which should be good - lots of extras and excellent commentries etc. It won't be the "remastered" version which wasn't well received.
Gareth
#115369 - 09/09/2002 17:38
[Re: dodgecowboy]
There aren't 50, only 2. They are linked up to any number of systems, but physically, only two boxes exist.
Finally a topic on this board that I know crap about
#115370 - 10/09/2002 03:09
Re: black boxes :-D
[Re: eternalsun]
I remember the first few times I went out to the Falklands they used VC10's with the seats all facing backwards. It's actually much more relaxing than most folk think...except for the climb immediately after takeoff, when you do feel like you are hanging by your lap belt:-)
Then again, I always prefer to sit in a rear facing seat on trains, somewhere near the rear of a carriage.
Paranoid? Me? Nahh.
#115371 - 10/09/2002 12:26
[Re: maczrool]
Loc: San Jose, CA
While I'm not going to say every technological advance can be incorporated into aircraft for no money, there are savings to be had. Consider the lawsuit money involved whenever there is a crash or a hijacking? I think mostly from a psychological/human standpoint, nobody will allow it to happen. For decades, manufacturers have wanted to put fly-by-wire into passenger aircraft, and I think to this day most of them are still fly by cable.
Calvin
#115372 - 10/09/2002 12:28
[Re: dodgecowboy]
Loc: San Jose, CA
Good god, if there was 50 of them, they would never find the right one when there is a crash!
Calvin
