#116366 - 14/09/2002 07:26 Another Failing HDD?
alfaguy
I've been getting the HDD not found error with an occasional failed to unmask IDE thrown in.
I've already replaced the HDD cable, and the player was in for service once and had the IDE header resoldered. (Thanks David)
This is a 60GB unit with two HDD's, any way to tell which drive is the problem from the boot log which I've posted below?
FWIW, I also tried disconnecting each of the drives as well as swapping their positions, this made no difference. This problem started out intermittently usually first thing in the morning when things were a little cool and has progressed to its present state where more times than not the player won't boot. Deifinitely temperature related though.
And yes, my player has the dreaded Fujitsu drives :-(
TIA,
Jeff
empeg state support initialised 0089/88c1 (save to d0004c00).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:0f:8
7
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...VFS: Cannot open root device 03:05
Kernel panic: VFS: Unable to mount root fs on 03:05
#116367 - 14/09/2002 09:50 Re: Another Failing HDD? [Re: alfaguy]
Since it's the root device, it's the master drive. (You can also tell this from the 03:05, which is the device number, which indicates the fifth partition on the first drive on the first IDE controller.)
#116368 - 14/09/2002 17:10 Re: Another Failing HDD? [Re: alfaguy]
eliceo
My riocar, 60 gig with 2 fujitsus has similar problems. Mine seem to happen every 3 to 4 weeks though, and dont seem to be temperature related. Maybe my drives are failing .
After I applied the builder image the drives were being detected but i would still get the kernel panic 3:05 error, after I gave up and reinstalled everything it started to work. Just reloaded all my music and wating to hear from support to see what to do.
#116369 - 24/09/2002 17:45 Re: Another Failing HDD? [Re: eliceo]
misaochankun
Loc: South Florida, USA
I have this same issue, but with a 10 gig single drive unit, with I believe IBM drive. It is random, but I suspect a loose cable since it does rattle a bit in there.
S/N:010101910
#116370 - 24/09/2002 20:10 Re: Another Failing HDD? [Re: misaochankun]
Well, it's bound to rattle. The laptop hard drives themselves rattle quite a bit, plus a single-drive empeg is going to have the end of the IDE cable loose in the case.
#116371 - 25/09/2002 10:39 Re: Another Failing HDD? [Re: wfaulk]
misaochankun
They may rattle, but mine seems to rattle more than usual.
I also noticed that if I shake it a tad, the hard drive errors I get go away.
S/N:010101910
