#116490 - 15/09/2002 17:36 Empeg web interface for dummies
AlB
Loc: SF
Trying to hook up the web interface on my computer and having some troubles. Directions are fairly clear but dont want to screw my empeg up.
Downloaded cute ftp (5.0 XP 32bit) and logged in to my empeg OK (I think). I executed the RW and RO commands but cannot seem to move around in the empeg's directory in order to transfer the files to the right directory on the empeg
there is just a "/" in the right hand pane and it does not list the drive 0 and other directories. Am I doing some thing wrong in logging in?
Alternately can I use the command line FTP program to make the empeg RW and then transfer using the IE interface, going back to the command line to make it RO at the end?
I have attached the screenshot of the cute ftp as logged into empeg
114760-cute ftp screenshot.jpg (112 downloads)
#116491 - 15/09/2002 19:21 Re: Empeg web interface for dummies [Re: AlB]
There's something wrong, you should be able to see all of the empeg's file system in the right-hand pane. There should be a bunch of folders there.
#116492 - 15/09/2002 19:35 Re: Empeg web interface for dummies [Re: tfabris]
AlB
Loc: SF
yeah gave up on that and did the RW thru command line, added files via IE and then set to RO with the command line. Had to upgrade to IE 6 to not get the EEEEEE mode but I still cannot get the Now playing interface to work. I addede the notify=1 in the config file via emplode edit tool and it still comes up with the message to add the notify=1.
Is there any special place I should add this? I just put it at the end of the config file....
#116493 - 15/09/2002 19:40 Re: Empeg web interface for dummies [Re: AlB]
It must be under a heading called [output] but it can be anywhere in the file as long as it's under that heading.
#116494 - 15/09/2002 20:59 Re: Empeg web interface for dummies [Re: tfabris]
AlB
Loc: SF
Ok so now I got it to work...sort of. I dont have the ability to insert append or enque files. What ever mode I use to add files on the interface the empeg will play only that single file???
I cannot stream audio to any player (WMP 9, Winamp) I get the attached screen is I try... Otherwise it is a very nice program...
114786-wmp9 screen.jpg (102 downloads)
#116495 - 16/09/2002 08:28 Re: Empeg web interface for dummies [Re: AlB]
maniac8888
Loc: San Jose, CA USA
I had this problem untill I upgraded to IE 6.x even when I had IE 5.5 w/XML core services.Once I upgraded, everything was as it should be.
