#116555 - 16/09/2002 07:07 Outlook Express bottom posting
For those of you that use OE and hate its reply quoting style, check out OE-QuoteFix. It absolutely Does The Right Thing.
Of course, the number of you that use OE and actually care to DTRT is probably pretty small. But there are those of use that are forced to use it.
#116556 - 16/09/2002 07:39 Re: Outlook Express bottom posting [Re: wfaulk]
David
Loc: Cambridge
I used this and found it caused OE to hang and just generally act weird.
#116557 - 16/09/2002 08:05 Re: Outlook Express bottom posting [Re: David]
I can believe that. Do you have a better solution?
#116558 - 16/09/2002 08:19 Re: Outlook Express bottom posting [Re: wfaulk]
It worked fine for me, but I didn't use it much. We kinda have to use Outlook, rather than OE. Anything I could use OE on, I use mutt, anyway.
#116559 - 16/09/2002 13:20 Re: Outlook Express bottom posting [Re: wfaulk]
David
Loc: Cambridge
Read through http://learn.to/edit.messages, then edit the message manually.
#116560 - 16/09/2002 13:51 Re: Outlook Express bottom posting [Re: David]
Yeah, yeah. Up yours, too.
I'ts just a PITA to fix up what OE decides to generate. I decided to just install PC-Pine and forget about it.
