#117073 - 19/09/2002 20:27 Can this be done ?
dcosta
Loc: Massachussetts
<beta 13 release notes>
Developers: when telling the player what to play by supplying FID numbers
over the serial port, you can now select whether the new FID replaces the
current content (as before), or is appended (follow the FID with "+"), or
Enqueued (follow it with "-"), or Inserted ("!").
</beta 13 release notes>
Can this be done over ethernet.... through a web browser... ???
__________ davecosta Hijacked 60GB MKIIa 2.0b13
#117074 - 19/09/2002 22:01 Re: Can this be done ? [Re: dcosta]
Yes. It's built in to CharcoalGray99's XML pages, found here.
#117075 - 20/09/2002 23:30 Re: Can this be done ? [Re: tfabris]
jakobstone
Loc: Dallas, TX
I cannot seem to get a connection to my player, how do I point my laptop to the player if i use ethernet?
60 GB Blue Platinum Silver Subaru WRX Dallas, TX
#117076 - 21/09/2002 07:37 Re: Can this be done ? [Re: jakobstone]
DeadFire
The two easy things to check for are to make sure you have Hijack installed, and also, in order to run an ehternet cable from the laptop directly to the empeg, it must be a crossver cable, not a normal one.
I happen to do it with normal cables with the use of a small hub. Sometimes people drop by with their machines.
Edited by DeadFire (21/09/2002 07:38)
#117077 - 21/09/2002 08:21 Re: Can this be done ? [Re: jakobstone]
FAQ Entries:
Can I connect to my player 'by name' over ethernet?
Can I connect to the player via FTP or HTTP?
Why can't I get ethernet to work?
This has also reminded me that I need to add a note to one of those entries...
