#117238 - 21/09/2002 09:01 Disable serial port in config.ini
Could we get an option in config.ini to stop the player from hogging the serial port? I might finally get my GPS compass written then!
#117239 - 21/09/2002 12:50 Re: Disable serial port in config.ini [Re: andym]
Loc: Los Angeles, CA
supress_notify=1?
#117240 - 21/09/2002 14:35 Re: Disable serial port in config.ini [Re: image]
I think he means to prevent the Player app from having exclusive control over the serial port while it's running (which prevents a third-party app from making use of the serial port without first terminating the player app).
Wasn't there already a way to work around this? I thought Kim's project already handled this situation.
#117241 - 21/09/2002 15:36 Re: Disable serial port in config.ini [Re: tfabris]
Doesn't starting the player with the `-s-' option do that? I think other folks talked about that here before, but it's not listed in the ``Player Command Line Arguments'' section of the Player App section of Developer Info on riocar.org.
If so, then moving the player app to a different file and replacing the original filename with a script like:
#!/bin/sh
player.new -s- "$@"
should do the trick, I think (read the postscript below).
Edit: It's "-s-", not "-s" (fixed it above), and, apparently, my idea doesn't work. Check out this thread.
Edited by wfaulk (21/09/2002 15:45)
#117242 - 21/09/2002 15:43 Re: Disable serial port in config.ini [Re: wfaulk]
mtempsch
Looking in the programming forum, the switch might actually be -s-.
#117243 - 22/09/2002 03:48 Re: Disable serial port in config.ini [Re: wfaulk]
I think a config.ini option is the best way to get it working, is there an official wish list this can get added to? I doubt it's a serious mod anyway.
#117244 - 22/09/2002 11:17 Re: Disable serial port in config.ini [Re: andym]
I don't mean to be a naysayer, but you're going to have to modify the init (or something) in order to get your GPS compass to work anyway, right?
At the same time, I doubt that it would be a significant modification, but that doesn't necessarily mean that they'll do it. It's their baby, after all.
#117245 - 22/09/2002 13:16 Re: Disable serial port in config.ini [Re: wfaulk]
I'm not really a Linux-head so I'm limited by my knowledge. All I do know is the renaming of the player and using a shell script to launch the player screws hijack up. So really it's either needs to be a mod in the player app or Mark needs to see why the renaming of the player binary stops Hijack from being able to read the config.ini file. Unless someone knows of another way..... anyone? anyone? bueller?
#117246 - 22/09/2002 13:37 Re: Disable serial port in config.ini [Re: andym]
smu
Loc: Germany (Ruhrgebiet)
The reason HiJack isn't able to read the config.ini when the player is renamed is that it check's for the name of the process that tries to read config.ini and only reads it itself if that name is the name of the player binary.
Solution: Don't rename the player binary, but move it to a different directory. After that, your script needs to chdir to that directory and start the player from there.
Other solution: Rename/replace the init script instead of the player app. The script doesn't do very complicated things anyway, just mounts the partitions, starts the player app in a loop. In that loop, it also starts a shell of the player exits with a certain return/exit level. (See the developer section on riocar.org for more details).
cu,
sven
#117247 - 22/09/2002 13:54 Re: Disable serial port in config.ini [Re: smu]
Thanks Sven! I'll give that a go tomorrow. GPS here I come!!!
#117248 - 22/09/2002 19:48 Re: Disable serial port in config.ini [Re: andym]
I did this in the thread that Bitt linked to earlier and had no success though. I will definitely be interested in a solution though.
Now that I have sourced an empeg tuner, I have to get my Alpine CD changer software/hardware interface to work properly, which requires talking to the serial port. Also have that GPS... hmmm I'm out of serial ports .
#117249 - 23/09/2002 08:05 Re: Disable serial port in config.ini [Re: Shonky]
jaharkes
Along with the gps app I wrote there is a tiny little program (hack_init) that succesfully hacks the init binary to start a wrapper instead of the real player app. It adds the -s- flag to the arguments when it notices that the player is booted in the car. It works for me, otherwise I wouldn't have been able to
get the GPS output in the first place.
#117250 - 23/09/2002 12:38 Re: Disable serial port in config.ini [Re: jaharkes]
That sounds cool, does Hijack still work after this mod has been done?
#117251 - 23/09/2002 15:28 Re: Disable serial port in config.ini [Re: andym]
jaharkes
Ehh, it should. The player is exec'd with the full name that hijack expects /empeg/bin/player. I need hijack anyway to display the graphics, but I'm not using any of the @AC or whatever modifiers in config.ini.
#117252 - 23/09/2002 15:56 Re: Disable serial port in config.ini [Re: jaharkes]
Brilliant! That's what I'll use then. Thanks ever so!
#117253 - 24/09/2002 04:13 Re: Disable serial port in config.ini [Re: smu]
Could someone tell me how to write this in a script? when I type chdir it says command not found.
#117254 - 24/09/2002 06:03 Re: Disable serial port in config.ini [Re: andym]
The command is ``cd''. Let us know what other help you might need.
#117255 - 24/09/2002 07:19 Re: Disable serial port in config.ini [Re: wfaulk]
Okay, I've copied the chmodded the player app into a directory called 'noserial' inside /empeg/bin. Currently my script looks like this:
#!/bin/bash
cd /empeg/bin/noserial/
player -s-
The player says it can't find the file called 'player'
#117256 - 24/09/2002 08:15 Re: Disable serial port in config.ini [Re: andym]
mtempsch
./player -s-
Current directory isn't normally part of $PATH
Also make sure it's executable.
#117257 - 24/09/2002 09:32 Re: Disable serial port in config.ini [Re: mtempsch]
it still doesn't work. Once I run the player script I get a load of this...
[hijack] ERROR: : "no memory"
/empeg/bin/player: /empeg/bin/noserial/: is a directory
kmalloc: Size (262873) too large
hijack: no memory for parsing config.ini; skipped
VM: killing process player
buffermem : 331776
page_cache_size : 81
nr_free_pages : 90
num_physpages : 4096
/empeg/bin/player: line 2: 177 Killed /empeg/bin/noserial/
buffermem : 331776
nr_free_pages : 91
/empeg/bin/player: line 3: 178 Killed player -s-
What am I doing wrong?
#117258 - 24/09/2002 11:54 Re: Disable serial port in config.ini [Re: andym]
jaharkes
That won't work, believe me I tried that at first as well.
First of all, as others reported earlier on the BBS /bin/init cannot exec shell scripts, only binaries. So whatever it starts it better be a compiled program.
Second, hijack explicitly matches on /empeg/bin/player, that is the only executable on the system that will see a modified config.ini file.
That's why I wrote hack_init for my gps application.
#117259 - 24/09/2002 14:04 Re: Disable serial port in config.ini [Re: jaharkes]
Thanks Yan, I'll download your stuff and use hack_init.
#117260 - 25/09/2002 19:57 Re: Disable serial port in config.ini [Re: jaharkes]
Shouldn't need to hack init: Hijack looks for /sbin/hijack before init during startup..
