Page 5 of 5 < 1 2 3 4 5
#117545 - 12/10/2002 16:44 Re: GPS app (less talk, more action) [Re: jaharkes]
Warp10
Loc: Germany
Wow man, that's great news. I'll give the modified HJ a try tomorrow.
As usual, I've got something I was wondering about: My GPS receiver (a simple GPS mouse) stopped working a few days ago (I've already gotten a replacement). It was permanently connected to the empeg's serial port. So maybe it quit working because the empeg was sending some 'weird' data to the GPS-Receiver (at least from the point of view of the receiver ;-). Is it a problem that the receiver always sends data simultaneously while the empeg sends data? Or could it be that the output from the player re-programmed the GPS-receiver's bios (or whatever)? Should I only connect the GPS-receiver if I have gpsapp running?
Edited by Warp10 (12/10/2002 16:45)
---------------------------- MK1: 00314 (4GB) MK2a: 030103104 (30GB) Installed in a BMW 323ti
#117546 - 12/10/2002 16:51 Re: GPS app (less talk, more action) [Re: Warp10]
jaharkes
The kernel does send out some messages during bootup, if you don't have car_serial_rate and notify, the player shouldn't be sending anything. However I don't think either of these would 'reprogram' a receiver.
The used protocols typically use non-ascii characters and checksums to avoid such things from happening. How is that receiver powered? I might be a power spike, 12V in a car isn't really regulated, so it can be anywhere between 9 and 16, (or even worse? maybe I should add a diode to protect my gps from negative voltages).
#117547 - 12/10/2002 16:57 Re: GPS app (less talk, more action) [Re: jaharkes]
Warp10
Loc: Germany
The receiver runs at 5 Volts. I'm using a simple fixed voltage regulator. It's buffered with a high capacity cap and sufficiently cooled. I don't think that's the problem, do you?
#117548 - 12/10/2002 19:00 Re: GPS app v0.4 [Re: jaharkes]
Happy Birthday Daria
Incidentally, the python script gets really pissy if your web browser plays with the web page at all when writing it out. Both saving page as .txt and .html in Mozilla write out something useless; When I use wget, it's fine.
#117549 - 12/10/2002 20:30 Re: GPS app v0.8 [Re: Daria]
jaharkes
I use mozilla myself and use 'save link target as html'. But yeah, the python parser isn't that pretty and easily gives up when the input doesn't really match the couple of routes I tried. There are 2 html options, for one of them mozilla also grabs the images and rewrites the html output, my guess is that the rewrite breaks the parsing.
In a way the mapsonus routes should be a temporary solution as I want to get on-line routing in gpsapp at some point.
btw. fixed the Trimble TSIP protocol, turned out to be that the ARM uses a slightly different layout for double precision floating point numbers. v0.8 has just that one little change.
#117550 - 12/10/2002 20:40 Re: GPS app (less talk, more action) [Re: Warp10]
jaharkes
With a regulator in between, receiver damage due to power spikes is unlikely. I do find it hard to believe that ascii text written to the serial port could cause permanent damage to your receiver. Perhaps the company provides a flash upgrade or windows drivers so that if something like this happens again you can simply reflash it.
#117551 - 12/10/2002 21:14 Re: GPS app v0.8 [Re: jaharkes]
Agree. I contemplated writing it in perl for about 30 seconds, then figured there were more permanent improvements that could be done (not that any of them are now done.)
#117552 - 13/10/2002 04:14 Re: GPS app (less talk, more action) [Re: jaharkes]
Warp10
Loc: Germany
What about empeg's serial port? Maybe there are power spikes or even negative voltages at the moment I power on the empeg?
#117553 - 13/10/2002 11:50 Re: GPS app (less talk, more action) [Re: Warp10]
jaharkes
The serial port is supposed to use -12v and 12v signal levels and the inputs typically have pretty high impedance, I don't think you can kill a serial input line, except when you go crazy with the voltages (25V and over..) Haven't looked it up or anything, I guess a max233 datasheet could give a 'reasonable ballpark figure'.
