#119319 - 03/10/2002 21:25 cannot access player database
cblake
Okay heres the scenario.. I just got my spare 12gb mk2a today. I cannot get emplode to access the players database though. My other player works fine and I have no problems with it. I got them hooked up to a netgear router and when I goto load the player database on the spare one it just says "operation completed successfully" but won't let me do anything. Any ideas? I am currently reding the FAQ to check and see if I missed anything.
Calvin
40GB Mk2 [blue]blue[/blue] 90000660 Driveless Mk2a [blue]blue[/blue] 120001040
#119320 - 03/10/2002 21:34 Re: cannot access player database [Re: cblake]
genixia
Check software versions?
ie, if the player is running v1.03, then Emplode should be v1.03
if the player is running v2betaX, then Emplode should be v2betaX
(Apparently differences in the minor revision number shouldn't make a difference, but v1 versus v2 will.)
#119321 - 03/10/2002 22:50 Re: cannot access player database [Re: genixia]
cblake
Doh.. Gotcha.. It is running v1.03 so that should be the problem. Thanks.
-Calvin
