#120416 - 12/10/2002 13:20 anyone speak french?
RobotCaleb
googles translation sucks horribly and i cant make much sense of it.
salut, voila, lorsque je met a jour psychostats par le fichier stats.pl il me remet tout a zero y compris les modifs de couleur que g aporté ds le fichier pstats.css. Ma demarche est la suivante : - lancement de stats.pl (les 1ere mise a jour s'effectue corectement) - supression des anciens logs deja mis a jour (pas de pb jusque la) - 2eme misa a jour avec les new log (tout se remet a zero). Que dois-je faire? Je dois quand meme pas garder tout les logs. Ca risque de devenir imposant sur mon DD au bout d'un moment. Et en ce qui concerne mes modifs de couleur que se passe t'il? Merci.
#120417 - 12/10/2002 15:13 Re: anyone speak french? [Re: RobotCaleb]
This is a quick translation. I believe it's pretty accurate, even if I don't have a clue what's it about.
Hi! When I made the psychostats up to date with the stats.pl file he put me back to zero and included the colour changes that I implemented with the pstats.css file.
This has happened : I ran the stats.pl file (the first update went ok) - supression of older log files that were already up to date (no "pb" (?) up to that point) - second update with a new log (everything put itself back to zero).
What can I do? I really don't have to keep all my logs? If yes, those logs will occupy a great deal of harddisk space in the future.
And what will happen with regard to my colour ajustments? Thanks!
#120418 - 12/10/2002 19:57 Re: anyone speak french? [Re: BartDG]
svferris
Loc: San Diego, CA, USA
Is there anything that somebody on this board can't do? I love it.
#120419 - 12/10/2002 20:49 Re: anyone speak french? [Re: BartDG]
RobotCaleb
thanks alot man, appreciate it.
#120420 - 13/10/2002 02:28 Re: anyone speak french? [Re: RobotCaleb]
No problem, glad I could help!
#120421 - 13/10/2002 18:50 Re: anyone speak french? [Re: svferris]
Lick themselves between the shoulder blades?
#120422 - 13/10/2002 20:15 Re: anyone speak french? [Re: canuckInOR]
You never know. One of these folks might own an empeg.
#120423 - 14/10/2002 08:23 Re: anyone speak french? [Re: BartDG]
f_devocht
Loc: Belgium
pb = problem
#120424 - 14/10/2002 11:52 Re: anyone speak french? [Re: tfabris]
svferris
There was a guy on Ripley's Believe it or Not that could turn his head a full 180 degrees. Maybe he can lick between his shoulder blades?
#120425 - 14/10/2002 20:01 Re: anyone speak french? [Re: tfabris]
I looked at the photo gallery. Two things went through my mind. One was "Ouch." The other wasn't printable.
#120426 - 15/10/2002 06:31 Re: anyone speak french? [Re: f_devocht]
pb = problem
Obviously ! I can't believe I didn't think about that one!
