#123371 - 28/10/2002 17:01 dead
akihiro
Loc: Kanagawa Japan
I use jEmplode.
I send "empeg car Version 2.00-beta13" to Hijack kernel position.
now not boot my empeg.
too bad mistake.
how to repair this case?
#123372 - 28/10/2002 17:24 Re: dead [Re: akihiro]
- Remove the power from the player.
- Get the proper ".upgrade" file as described here.
- Connect the player to your computer's serial port. Do not apply power to the player.
- Double-click on that .upgrade file. If you've got a version of emplode installed, it should begin running the upgrade software. Follow the software's prompts.
- Do not apply power to the player until the upgrade software specifically prompts you to do so.
- When the software tells you to apply power to the player, do it. It should upgrade the player and replace the bad kernel properly.
#123373 - 28/10/2002 19:47 Re: dead [Re: tfabris]
DeadFire
Hey, Tony, aren't those instructions in the FAQ somewhere... like everything else?
Why did you type it all out?
#123374 - 29/10/2002 00:34 Re: dead [Re: DeadFire]
Actually, it's in the text linked by the word "HERE" in the above post. But I wanted to make sure he "got it".
#123375 - 29/10/2002 04:25 Re: dead [Re: tfabris]
akihiro
Loc: Kanagawa Japan
Let me explain in details.
I applied power to the player only to come out nothing on the display, just LED on the right side blinked. The player doesn't answer me.
I think the cause is that I failed to write a file called "car2-consumer-v2.00-beta13.upgrade" to Hijack Kernel, not Empeg Upgrade. The file is in Upgrade Empeg which is in the tool box of Jemplode.
I tried just as you wrote down but in vain. My computer says "car player not found."
Am not I able to restore the player under this condition?
#123376 - 29/10/2002 05:27 Re: dead [Re: akihiro]
AndrewT
Loc: Oxford, UK
Are you certain you tried using the serial (RS232) port?
I expect that your Emplode is configured to use the ethernet or USB connection to the player by default.
#123377 - 29/10/2002 05:41 Re: dead [Re: AndrewT]
akihiro
Loc: Kanagawa Japan
Yes.
I tried using the serial port.
but Upgrade wizard say ..
Error "Car player not found: Check your serial connection and ensure that Hyper Terminal (or similar) occurred during stage 0x00
#123378 - 29/10/2002 06:02 Re: dead [Re: akihiro]
Greetings!
What kind of machine are you using to sync? Are you connected on a Windows machine? Did anything else have the serial port to the player open (like HyperTerminal)?
#123379 - 29/10/2002 06:24 thank you so much everyone! [Re: akihiro]
akihiro
Loc: Kanagawa Japan
serial port was used by another application and could't be used for Empeg.
now I changed a system and it's now used by Empeg.
Thank you so much everyone!
