#123757 - 30/10/2002 19:42 HD not found :(
BAKup
Loc: Houston, TX
All of a sudden the player just locked up, and on boot the dreaded "No hard disk found Contact support"
Here's the log from when both HD's are hooked up, if I pull one, the only change is the log lines for that HD are missing.
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.14-rmk5-np17-empeg51 (mac@aphex) (gcc version 2.95.3 20010315
(release)) #17 Wed Jul 24 18:23:20 BST 2002
empeg-car player (hardware revision 9, serial number 30102576)
Command line: mem=16m
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005a00).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IBM-DJSAm2q0` ` ` ` ` ` ` ` ` ` ` ` ` `, ATA DISK drive
hdb: FUJITSU MHL2s0pAT ` ` ` ` ` ` ` ` ` ` `, ATA DISK drive
hda: IBM-DJSAm2q0` ` ` ` ` ` ` ` ` ` ` ` ` `, 16127MB w/8576kB Cache, CHS=32767/
16/63
hdb: FUJITSU MHL2s0pAT ` ` ` ` ` ` ` ` ` ` `, 16127MB w/10240kB Cache, CHS=32767
/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:0a:1
0
Partition check:
hda: unknown partition table
hdb: unknown partition table
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...€,]]Y[üº to access beyond end of device
03:05: rw=0, want=2, limit=0
dev 03:05 blksize=1024 blocknr=1 sector=2 size=1024 count=1
EXT2-fs: unable to read superblock
Kernel panic: VFS: Unable to mount root fs on 03:05
--Ben
78GB MkIIa, Dead tuner.
#123758 - 30/10/2002 19:51 Re: HD not found :( [Re: BAKup]
You've looked at this already, right?
#123759 - 30/10/2002 20:14 Re: HD not found :( [Re: tfabris]
BAKup
Loc: Houston, TX
The only items in the list that could be affecting me would be
Dry Solder joints
Faulty CS4132A chip
(I've just got done putting on the cable and HD from the other player into this one) So it can't be a bad cable, or HD.
edit: And I've used two different Empeg power supplys, so it's not that either.
Edited by BAKup (30/10/2002 20:16)
--Ben
#123760 - 30/10/2002 20:18 Re: HD not found :( [Re: BAKup]
Sometimes the cables work loose inside the player after you've closed it all up, so don't immediately assume the solder joint problem. But do check for both.
#123761 - 30/10/2002 20:43 Re: HD not found :( [Re: tfabris]
BAKup
Loc: Houston, TX
I was booting it just hooked to the board, not sealing it all the way back up due to the fact that I'm not that much of a glutton for punnishment (Though I'm currently on my 6th straight listen through of Scarlet's Walk)
It turned out to be a cold joint, heated up the iron, and ran through the joints, and it started booting up fine when I hooked back up the drives.
Now back to Tori
--Ben
#123762 - 31/10/2002 11:35 Re: HD not found :( [Re: BAKup]
Now back to Tori
