#125649 - 11/11/2002 14:56 Build 13 blues :(
belezeebub
Well I replaced a bad drive in my player re-uploaded everything and went to build 13 to boot and here is my problem
Issue 1.
On random songs the player seems to lock up and requires a remove and replace from the sled to fix it (This seems to be on the same songs so the songs might be bad not sure why bad songs would cause a lock up)
Issue 2
Known good songs will seem to pause for a brife second durning playback
Issue 3
1 out of 20 times the player will keep playing for 20 seconds or so AFTER the key is switched off... no reason and very random
HELP
______________________________________ Do not meddle in the affairs of Network Administrators, for they are subtle and quick to anger. ______________________________________ Worlds Lamest Wb Site (mine) http://home.comcast.net/~jlipchitz/
#125650 - 11/11/2002 15:07 Re: Build 13 blues :( [Re: belezeebub]
belezeebub
more info
All the tracks are are made with MMJB using 320kbs and cranking up the freq responce to max....
Also I need to pick up a new cable for my player I think mind is bad or might be bad anyone know where to find them ??
#125651 - 11/11/2002 15:54 Re: Build 13 blues :( [Re: belezeebub]
May not have just been a bad drive. Could be cable problems or IDE header. Did you go through the FAQ entry on this topic?
#125652 - 11/11/2002 16:29 Re: Build 13 blues :( [Re: tfabris]
belezeebub
I mounted the drive up in my desk top and it wouldn't spin up
