#126338 - 15/11/2002 16:00 Disable Aux Mode with Hijack?
Allistah
I was just wondering if there was a way to completely disable the Aux mode with Hijack or other means. I never use it and probably never will. It would be cool if it was a config option in Hijack that would take it out of the loop when I'm pressing the knob and just have it alternate between the player and the radio only.
Thanks for any info anyone might have.
-Allistah
#126339 - 16/11/2002 01:43 Re: Disable Aux Mode with Hijack? [Re: Allistah]
jarob10
Loc: Stockport, UK
Great idea ! Similarly, I would like an option to disable AM tuner reception.
#126340 - 16/11/2002 05:13 Re: Disable Aux Mode with Hijack? [Re: Allistah]
boxer
Loc: Yorkshire UK
I'm for that, I put it on the wish list sometime ago.
#126341 - 18/11/2002 10:55 Re: Disable Aux Mode with Hijack? [Re: boxer]
Allistah
I guess theres no way to currently do this. I hope they add it at some point. Would be a cool little feature. To be able to not have any or all the inputs (radio/player/aux).
#126342 - 18/11/2002 13:57 Re: Disable Aux Mode with Hijack? [Re: Allistah]
number6
I think you will find that you can implement this functionality using Hijack Ir translation rules.
In that you can say "when I press the remote Source button and I am in Player mode send 3 source button presses to the player', which will switch it from Player to Aux, then AM then finally FM.
And you leave the existing behaviour unaltered otherwise.
That way when you are in Tuner mode, you will advance to the next source, when in Player mode, source will skip straight to FM.
If by some reason you ended up in Aux or AM mode, then source will advance to the next mode (either AM or FM respectively for those two buttons).
Have a look in the rioar FAQ section on Hijack - there are some good instructions on how to do exactly this sort of thing.
#126343 - 19/11/2002 13:20 Re: Disable Aux Mode with Hijack? [Re: number6]
jarob10
Loc: Stockport, UK
Why didnt I think of that ?
Jeez, I feel dumb. Again.
