#127195 - 20/11/2002 13:32 Anyone use their Pocket PC as an EMPEG remote??
NicolasW
Loc: USA
Hey all -
Just got the new Dell Axim X5 Pocket PC (will arrive soon) and was wondering if it can be used as your EMPEG remote? I know there is a program for the Windows CE to act as a remote for your A/V components.
Wes
#127196 - 20/11/2002 13:51 Re: Anyone use their Pocket PC as an EMPEG remote?? [Re: NicolasW]
robricc
The Dell Axim doesn't seem to offer CIR (Consumer InfraRed?). Only IrDA. The new HP iPAQ also dropped this feature (I think).
Luckily, the empeg has an IrDA port. I think you would have to write some software to make use of it though. Excuse me if I'm talking out my ass.
#127197 - 20/11/2002 14:00 Re: Anyone use their Pocket PC as an EMPEG remote? [Re: robricc]
TheAmigo
Yeah, but you need to have IrDA support in your kernel (and probably IrCOMM or whatever protocol you want to use on top of that). It's not quite as simple as compiling the kernel modules either because there isn't loadable module support in hijack (not sure about the stock kernel).
If you do find a way to do it, I'd love to hear about it... I really wanna have IrDA too.
--The Amigo
#127198 - 20/11/2002 14:07 Re: Anyone use their Pocket PC as an EMPEG remote? [Re: TheAmigo]
link.
I can easily compile a kernel with IrDA support if you guys want. I have it already, but I was working on getting the audio overlay patch in before I posted it...
#127199 - 20/11/2002 15:37 Re: Anyone use their Pocket PC as an EMPEG remote?? [Re: NicolasW]
Ezekiel
Loc: NH USA
I've done it at home over 802.11b & empegvnc on my ipaq 3670. The empeg was hooked to my wired LAN. It was definitely workable, albeit there was a lag & the ipaq battery precluded all-day use.
-Zeke
WWFSMD?
#127200 - 21/11/2002 09:31 Re: Anyone use their Pocket PC as an EMPEG remote?? [Re: Ezekiel]
pupvogel
Loc: Hamburg, Germany
Philips has a software ('ProntoLite') for PalmOS which should turn a Palm into quite a flexible remote control.
It's $19.95, but you can download it for evaluation - because they don't know if it works for you...
For me it doesn't - don't have a Palm .
#127201 - 21/11/2002 09:57 Re: Anyone use their Pocket PC as an EMPEG remote?? [Re: pupvogel]
revlmwest
Loc: Hartsville, South Carolina for...
I use a program called OmniRemote. It worked right out of the box. Of course this is Palm OS but it should have a PC equivalent.
Michael West
#127202 - 21/11/2002 11:09 Re: Anyone use their Pocket PC as an EMPEG remote?? [Re: revlmwest]
Neutrino
Just search for pocket pc remote and you'll find one. I downloaded a version a few months back. It works.
#127203 - 21/11/2002 14:06 Re: Anyone use their Pocket PC as an EMPEG remote? [Re: revlmwest]
TheAmigo
I've used OmniRemote and it had all the features I was looking for... pretty slick.
The problem I found is that my Palm (IIIx) like most doesn't have a strong enough IR transmitter to work farther than an arm's length away (kinda defeates the purpose of a remote). Some of the newer ones do have better IR range (like 20 feet or so), but it's often hard to tell before you buy. IIRC, Sony started listing which of their Clie models are universal remote capable. I think those also come with software that Sony wrote to use that. I don't have one so I can't say if it's any good or not.
--The Amigo
#127204 - 21/11/2002 14:09 Re: Anyone use their Pocket PC as an EMPEG remote? [Re: TheAmigo]
revlmwest
My m500 will work from at least twenty feet...maybe more but I don't want to be that far from my empeg.
Michael West
#127205 - 21/11/2002 14:17 Re: Anyone use their Pocket PC as an EMPEG remote? [Re: TheAmigo]
leftyfb
Loc: Lowell, MA
I used to use Omniremote all the time. Even bought one of their IR modules cuz I only had an ancient palm (Palm Pilot Personal) with no IR built in. It worked pretty well, I think it did 20+ feet or so.
Mk2a 30GB Blue. Serial 030102999
#127206 - 21/11/2002 14:21 Re: Anyone use their Pocket PC as an EMPEG remote? [Re: leftyfb]
TheAmigo
I remember reading about that. I felt gypped when I found out that some newer ones had long IR range and the older ones' add-on has long range, but not the III series, nor could I get an add-on IR.
--The Amigo
#127207 - 21/11/2002 20:31 Re: Anyone use their Pocket PC as an EMPEG remote?? [Re: NicolasW]
jasonc
I thought about this but came to the conclusion that using a 500$ pocketpc to use with the empeg seems less efficient than using the 12$ multifunction remote with which I can dim the lights, turn on the stereo, turn off the tv and vcr And control the empeg (thanks to hijack). <whew>
I always had a problem with run on sentences.
#127208 - 29/11/2002 22:52 Re: Anyone use their Pocket PC as an EMPEG remote? [Re: robricc]
The new iPaq 1910 does contain IrDA, but dosen't contail CIR, correct. The 54xx line does however still has both IrDA and CIR.
#127209 - 19/12/2002 11:29 Re: Anyone use their Pocket PC as an EMPEG remote?? [Re: NicolasW]
csf
Loc: Charlotte, NC
As a slight aside, I have found that you can wash your original empeg remote (yes, in the machine) and it will still work - provided you get a new battery.
Just a little FYI.
10+40 Gig Mk2a... with Tuner. S/N 040103784 || 2001 Jeep TJ, 60th Anniversary Edition
#127210 - 19/12/2002 11:35 Re: Anyone use their Pocket PC as an EMPEG remote?? [Re: csf]
#127211 - 19/12/2002 11:37 Re: Anyone use their Pocket PC as an EMPEG remote?? [Re: csf]
Yeah, and after it comes out of the wash, the IR signals are cleaner.
