#128008 - 25/11/2002 22:16 Fail making directory
ineedcolor
Loc: Windsor, Ontario Canada
Hello All
I am attempting to install DomoKun's awesome TTS Clock script into my player. I am using WinXP and ftp through the command line. I have to install Empeg-Preinit to allow the TTS scripts to work. Trouble is, the install fails while trying to create the preinit.d directory in the /etc folder on the player to contain the scipts. According to the Beagleboy's instructions, this is all supposed to happen automatically with a Windows install....Any suggestions?
#128009 - 25/11/2002 22:36 Re: Fail making directory [Re: ineedcolor]
DomoKun
Loc: Pennsylvania
Do you have the developer image of the player software installed or the consumer version? I'm pretty sure you need the developer image for this to work.
#128010 - 25/11/2002 22:43 Re: Fail making directory [Re: DomoKun]
ineedcolor
No I don't...and I'm suprised that this is not mentioned in the Beagleboy's installation instructions...I'll give that a try then.
Thank you
Edit: I think that was it Rob, once I installed the developer image, things seemed to go a whole lot better, I'll test it in the car tomorrow...thanks again for your help...
Edited by ineedcolor (25/11/2002 23:18)
#128011 - 29/11/2002 09:24 Re: Fail making directory [Re: ineedcolor]
ineedcolor
Here's an update:
IT WORKS, IT WORKS!!!!! and it works damn well too. Installing the developer image did the trick...
Thank you for a great piece of work Rob!
