#12826 - 03/08/2000 15:02 VBR ff/rw
Geoff
Loc: Northern Ireland
Has there been any progress at getting FF & RW working with tracks encoded using VBR?
I noticed it is still a bit flaky in RC1, works with some tracks, not in others.
Aside from that, I haven't noticed any other problems with RC1 so far.
Geoff
Got one of the first Mark 2 empegs...
Geoff
Mk1 Blue - was 4GB, now 16GB
Mk2 Red - was 12GB, now 60GB
#12827 - 03/08/2000 15:52 Re: VBR ff/rw [Re: Geoff]
Actually, I was under the impression that the FF/REW with VBR wasn't going to work properly until they switched to the new decoding engine. I thought it was supposed to start working at the same time we got .WAV and .WMA playback.
guys@empeg? Confirm/Deny?
#12828 - 03/08/2000 17:13 Re: VBR ff/rw [Re: tfabris]
Geoff
That rings a bell now you mention it...
I rarely find myself using FF or RW when in the car, but I was trying it today when a track skipped while gaptest2 was running...
Don't panic!!! (in large friendly letters!) Nothing to do with the player, it was a badly ripped/encoded track I hadn't noticed before - guess I was multitasking when that slipped through
Geoff
Geoff
#12829 - 03/08/2000 18:38 Re: VBR ff/rw (developers read this) [Re: Geoff]
ClemsonJeep
Loc: Ashburn, VA
Hey guys,
I'm on a team writing a combo media organizer/player and we also use XAudio for our MP3 playback. I took it upon myself to fix the VBR problems that we were having with the stock XAudio stuff. We also had problems seeking to a certain point in the stream, until I found out some interesting information. There is a "VBR header" stored in the first frame of a VBR MP3 file. (At least ones encoded with Xing's encoder, but I'm not aware of another encoder that does VBR, and if there is one, I would assume they would implement Xing's header also)
Anyway, the VBR header stores information such as the total bit stream frames, the total bit stream bytes, the encoded VBR scale, and also an array of 100 bytes that range from 0-255, which allow you to interpolate the values so you can find "seek points" in the MP3 file relatively precisely.
If you guys are interested in this information, I can provide you the files you would need to implement this code as I did to get your player working with VBR files.
Later!
(O|||||O)
(O|||||O)
#12830 - 03/08/2000 18:41 Re: VBR ff/rw (developers read this) [Re: ClemsonJeep]
Our own VBR code works very well - however, this isn't shipping in the empeg-car yet, only in the OEM product.
Xaudio is more of a "black box" - it, in theory, does the VBR index and interpolation stuff. It doesn't seem to work well though, and we don't have source.
VBR will improve when Xaudio gets replaced.
