#130454 - 11/12/2002 23:58 Distributed.net on the empeg
Ok, it's about time I officially start this project again, as the last time I did, my empeg had a serial number of 00359.
The first step failed, running the client. Bug 3000 is filed, hopefully the client will be fixed soon.
#130455 - 12/12/2002 03:58 Re: Distributed.net on the empeg [Re: drakino]
Bug 3000
Dude, it told you what the problem is. CONFIG_SYSVIPC is not enabled in stock kernels.
#130456 - 12/12/2002 08:24 Re: Distributed.net on the empeg [Re: drakino]
Drakino - if dnet get a workaround for the SYSVIPC issue and provide a version which works for us, please let us know. I generally run it on most of my sgi boxes (for raw power) but it's definitely cooler to crack while driving
#130457 - 12/12/2002 10:24 Re: Distributed.net on the empeg [Re: peter]
I know, but the older clients used to work fine, so it probably dosen't really need that to function. Talking on #Distributed, they seem interested in fixing it, hence the bug report.
#130458 - 13/01/2003 10:34 Re: Distributed.net on the empeg [Re: peter]
The maintainer of the Arm Linux client responded to the bug, he's going to release a pthreads version, thus making it compatible with the empeg again.
I figure I'll set up the client similar to the way I did back on my Mark 1. The buffers will be held in a ramdisk, as the client enjoys frequently writing to them. Then, on a timeout, the buffers will be copied from the ramdisk to the harddisk. Any suggestions on the timeout? I think last time I used seven minutes, that seemed to be a good balance to catch the short car trips, and also infrequent enough that the disks shouldn't be in rw mode too often. The actual rw time back then was about 2 - 4 seconds not including spinup time, I'm sure now that could be a bit quicker. Also, I only rwed the one partiton I had the buffers stored on, not everything.
#130459 - 14/01/2003 06:01 Re: Distributed.net on the empeg [Re: drakino]
Are you going to set it up with something like a /dnet partition and just rw that? I wonder if this is also the kind of thing that ext3 could make even safer - I am just looking for some justification to go ext3 because I want to play with it but I really have no need to
#130460 - 14/01/2003 07:08 Re: Distributed.net on the empeg [Re: drakino]
Do you want a version of the kernel with SysV IPC turned on? It'll take 5 minutes for me to do...
- Trevor
#130461 - 23/01/2003 18:36 Re: Distributed.net on the empeg [Re: tman]
No need, but thanks for the offer. I haven't had any time to look into this recently. By the time I do, the newer client will probably be out with the fix for the SysV IPC issue.
