#131088 - 17/12/2002 08:59 Acrobat Help
A common issue with Acrobat: file size.
I've been scanning in documents (B&W, letter sized). I then import them into Acrobat. These files will go on my company's web site. Unfortunately I can't get a proper size/quality ratio. I have example files from another company that they emailed to us. For example, I have a very nice quality, crisp B&W, 10 page pdf from them that is only 500KB. That's great, and I'd like to achieve that. However, the best I can do is a poor quality 6 page document that's about 400KB. So basically, I'm doing about 1/4 of the result I want. Unfortunately, I don't know Acrobat well enough.
I've been using Irfanview to batch convert the images with countless different settings. I've shrunk the sizes of the images to a variety of sizes, I've tried changing them from 2 to 256 colors, and I've tried saving them as BMP's, JPEG's, and TIFF's. Suprisingly, the BMP's worked best, probably because that's what they were originally, but the JPEG's were the largest by an extremely wide margin.
What am I doing wrong here?
#131089 - 17/12/2002 09:04 Re: Acrobat Help [Re: Dignan]
That 500k small PDF file... is it a scanned bitmap image? Or just plain text?
Bitmap images take more storage space than typed text. Did you ever consider OCR? Or typing?
#131090 - 17/12/2002 09:12 Re: Acrobat Help [Re: tfabris]
Oops, I kept trying to attach them untill I realized they're too big.
I'm not sure about that. Would there be something in the file information that would tell me if it was or not?
*edit*
Here they are. the one called "cuna.pdf" is the good one, and mine is the crappy one.
Edited by DiGNAN17 (17/12/2002 09:14)
#131091 - 17/12/2002 09:20 Re: Acrobat Help [Re: Dignan]
robricc
Are you capturing the pages?
Tools -> Paper Capture -> Capture Pages...
#131092 - 17/12/2002 09:27 Re: Acrobat Help [Re: robricc]
Hmm, interesting. No, I wasn't (I'm downloading the plugin at the moment, it wasn't installed). I was opening the first image of the series, then telling it to insert additional pages (for some reason, when you try to open multiple images, they each open as seperate pdf files). This is in Acrobat 5. In 4, there was an image option under the File>Import menu, but that has been removed for some reason.
#131093 - 17/12/2002 09:29 Re: Acrobat Help [Re: Dignan]
robricc
Capturing the pages is what converts the text on the scanned page from a graphic to text using OCR. This should save you a bunch of space.
#131094 - 17/12/2002 09:37 Re: Acrobat Help [Re: Dignan]
matthew_k
What you really want to do is get a copy of the files, and print them out to adobe acrobat. The file quality/size will be much better, and you'll be able to highlight text and search text. I'm not sure how well the OCR option rob mentioned is, that might be happy medium.
#131095 - 17/12/2002 10:47 Re: Acrobat Help [Re: robricc]
Wow, that paper capture thing did not do well. My document ended up looking like a ransom note
How to I print to Acrobat? I can't find any options in my other programs.
#131096 - 17/12/2002 10:58 Re: Acrobat Help [Re: Dignan]
Get a MacOS X machine or purchase Acrobat. I think that there are a few other less costly options, but I don't remember them right now.
Of course, you could write your docs in TeX and use its (now) built-in PDF output option.
#131097 - 17/12/2002 11:02 Re: Acrobat Help [Re: wfaulk]
Despite your love of Macs, I don't think the file that I'm basing mine against was created on one, so it must be possible I'm going to try to contact them and find out how they did it.
#131098 - 17/12/2002 11:07 Re: Acrobat Help [Re: Dignan]
Ezekiel
Loc: NH USA
When you install Acrobat (at least in v.4 which I have) it will install two printers - PDF Writer and Acrobat Distiller. You choose them from inside the application and configure like any other printers. PDF Writer is more straightforward. If it gives you problems, try Distiller. Distiller can also act independantly and convert postscript (.ps) to .pdf, although I've never used it this way.
Once you've got your .pdf of the graphic you can insert it as a whole page into another .pdf document.
HTH.
-Zeke
WWFSMD?
#131099 - 17/12/2002 11:14 Re: Acrobat Help [Re: Dignan]
matthew_k
Perhaps I wasn't quite clear enough... Just to clarify, you need to print the text document to acrobat, not the scaned pages. The scanning is what is throwing you off. PDFs of scanned pages are better than nothing, but they're nothing compared to a good PDF, as you're finding out.
#131100 - 17/12/2002 11:17 Re: Acrobat Help [Re: matthew_k]
Oh of course. I would definitely convert the original documents if I had them, but this is about 1000 pages in binders we're talking about. Not all of it will be PDFed, but a couple hundred will (in seperate files, of course).
#131101 - 17/12/2002 11:30 Re: Acrobat Help [Re: Dignan]
Note that Acrobat and Acrobat Reader are two different products. As Zeke said, Acrobat (which is not free) can produce PDFs via virtual printer drivers.
However, the reason that you're having problems, to reiterate what every one else has said and to try to be extra-clear, is that you are simply embedding pictures of documents within a PDF file. The reason that PDFs are so small is that they generally only include the text and just enough ``mark-up'' to make them look right. It has no way to significantly reduce the pictures you're embedding, though.
Edit: Oops. Forgot to replace my xxx placeholder with Zeke (as I forgot who I was ``quoting''.
Edited by wfaulk (17/12/2002 12:21)
#131102 - 17/12/2002 11:49 Re: Acrobat Help [Re: wfaulk]
Okay, I'm going to try to read up on what's going on a little more. I understood what people were trying to tell me, but I was trying to get across the fact that I was creating files the same way that the other organization created theirs. That is what is confusing me, the fact that I'm creating the same type of file yet can't get the same results.
*edit*
I just got off the phone with the person who created the good file. From what I gathered, he didn't do anything special. None of this text file stuff or anything. ALL he was doing was opening Acrobat, scanning in the files directly into the program, then saving them. He specifically said he was not saving it in any sort of text form (so that the text is searchable or editable). I'm now back where I started. My dad may have to settle for large file sizes.
ps-his only answer was that they had a better scanner. that doesn't seem like a satisfactory explanation to me.
Edited by DiGNAN17 (17/12/2002 11:51)
#131103 - 17/12/2002 11:54 Re: Acrobat Help [Re: Dignan]
robricc
If the text does not have to be searchable or editable, then why use PDF. For your useage it seems like the wrong format. Perhaps a low-color GIF or, dare I say, JPEG would be a better choice.
If it's just going to be read off the web (not downloaded) this may be a good choice. See what I did with our print catalogs here.
#131104 - 17/12/2002 12:15 Re: Acrobat Help [Re: robricc]
This is true. I think the desire is for a "Document". Putting up a bunch of gifs wouldn't be appealing to my boss
#131105 - 17/12/2002 12:23 Re: Acrobat Help [Re: Dignan]
David
Loc: Cambridge
The reason your scans are larger might be because of the type of image and the cleanliness of the scan. Are your documents more 'busy' than the others you're comparing to?
Make sure that the background of the image is plain white. If there are variances of grey, then use the levels or birghtness/contrast controls in the scanner software to remove it. The more contrast, the better the compression will be.
Scan at around 200dpi if the document is intended to be printed out again in bitmap (ie. 2-colour) mode - greyscale will reduce readability and increase file size. Save the file in a non-lossy format; TIFF is best (non-print oriented formats such as BMP don't maintain size/dpi settings).
When you save the PDF, you should get options for the compression type and dpi downsampling. Set it to JPEG at a suitable quality. Turn off downsample, as your scan is already at an optimum resolution.
*edit* Just realised that you can't use JPEG for bitmaps. Select ZIP or CCITT in the monochrome bitmap images section.
#131106 - 17/12/2002 12:35 Re: Acrobat Help [Re: David]
Those sound reasonable. I was worried about the level of gray. My files do appear greyer than theirs. I suppose he wasn't too far off, but it wasn't really the quality of the scanner, so much as the correct levels.
*edit*
Bingo. Gray area. I looked at the exposure levels in the scanner software. I ran two tests on an area of the scan, one with the "highlights" bar all the way to the right, which maxed out the gray levels, and one just below the peak of color. Both TIFFs were the same size, but when made into PDFs, the first one was 290KB, whereas the second was only 30. Thanks Peter.
*edit edit*
Sorry if I've been sounding impatient, but I'm grapling with the thought that I might have to re-scan 130 awkwardly-bound pages. That is if Irfanview can't make the necessary adjustments.
Edited by DiGNAN17 (17/12/2002 12:48)
